Shifter made from an hydraulic handbrake
Discussion in 'DIY peripherals' started by zigzag49, Apr 11, 2016.
  1. zigzag49
    zigzag49 Active Member
    721Coins
    Hello
    Here's a shifter has a hand brake basis, the return system was taken on the principle of one of my old which was fine, with two stops for not too great race and adjustable.
    The master cylinder was removed and later serve me for another pedal diy project.
    I'm pretty satisfied.
    The whole mechanism with a wheel below, in the bottom of a room shifter V and two springs on the bolt of each dimension.
    The two large rubber that serve as stops and bunting shock and noise
    And a video in action:p
    • Like Like x 5
  2. RacingMat
    21,022Coins
    Great!
    sympa !
    pour ton titre, je dirai que ce serait plutôt "Shifter made from an hydraulic handbrake"
  3. zigzag49
    721Coins
    You're right I change.:thumbs
    Tu as raison j'ai changer
