SFX-100 idiots guide
Discussion in 'DIY Motion Simulator Projects' started by Andrew McArthur, Jun 6, 2020.
  1. Andrew McArthur
    Andrew McArthur New Member Gold Contributor
    Manager
    48Coins
    Hi all
    New to the forum and so much information here to read through but looking for an idiots guide to setting up a 4 x SFX style actuators with the Thanos. All works fine from the buttons of the Thanos but stuck with why the units will not work in game.
    I have installed the plugin the iRacing but obviously missed a step or two. Does anyone have an idiots guide and it will have to be an idiots guide to getting this creature working?
    Thanks in advance
    150,674Coins
    +11,018 / 55 / -2
  3. Andrew McArthur
    Manager
    48Coins
    Very useful, the Thanos now says receiving data. However my Simucube keeps disconnecting and iRacing starts hanging, anyone come across this?
  4. Thanos
    Electronics Engineer
    United States
    2,848Coins
    You most likely have ground issues. You need to run common ground wire between everything, PC, motors, drivers, chassis etc... some device creates ground loop, I can guess that is the Simucube...
  5. Andrew McArthur
    Manager
    48Coins
    Thanks for the info, will start ground and ferrite project.
  6. Sim Freak
    Sim Freak Sim Freak Gold Contributor
    61Coins
    Hi Andrew, did you manage to resolve the issue with grounding and ferrite?
