Question Servo motors torque mode operation. Ard pwm -> motor controller -> servo
Discussion in 'Motor actuators and drivers' started by Trigen, May 30, 2021.
  1. Trigen
    Trigen Active Member
    2,872Coins
    Hello
    Im revisiting my old Head g system as i have 2 st60 600w servo motors i can spare if i go with it. I see in the manual that torque mode wants a -10v - 10v analog signal to control the torque and direction. To me that sounds like i need to use a Ardunio to send a PWM signal to a motor controller that then send the V signals to the servo motors on pins Vref 25 and AGND 13.
    This honestly sounds pretty simple. All id need is a PWN signal from ardunio that keeps on going. Im wondering though. Is there a way i can do this directly from the Ard to the servo motor and cut out the motor controller and 10v? Digital or analog.
    My main problem is the ardunio sketch
    I need to create a PWN signal.
    I need values over 127 to give a positive signal and under 127 to give negative for direction
    127 - 255 will be 0 -255 CW
    So i need to invert the number so 127 - 0 becomes a positive 0 255 with CCW direction
    Or 0 to 127 CCW where 0 is full speed and 127 255 CW where 255 is full speed
    Any in depth help is greatly appreicated
    I thought id just modify this fan code
    Code:
    // Arduino Uno code based hugely on the work of SilentChill, Avenga76, and a number of others.
    // Forked off to support right and left speed commands (R000 and L000, etc) as well as traditional S000 format.
    // Version - 02_23_2021
    #define FALSE 0
    #define TRUE 1
    #define BRAKEVCC 0
    #define CW 1
    #define CCW 2
    #define BRAKEGND 3
    #define CS_THRESHOLD 100
    // If left and right fan control is swapped, just swap the values defined here for LEFT and RIGHT.
    #define BOTH 0
    #define LEFT 1
    #define RIGHT 2
    // Idle speed setting if you want the Arduino to reset or cold start with some air flow. Useful for
    // providing a light wind for VR comfort. Range is 0 to 255. I use 20 with TerraBloom fans. Default
    // value is 0 to not surprise anyone but change as you wish. There are no checks on this so you can
    // break the code if you use values less than 0 or more than 255.
    #define IDLESPEED 0
    int inApin[2] = {7, 4}; // INA: Clockwise output
    int inBpin[2] = {8, 9}; // INB: Counter-clockwise output
    int pwmpin[2] = {5, 6}; // PWM output
    int cspin[2] = {2, 3}; // CS: Current sense ANALOG input
    int enpin[2] = {0, 1}; // EN: Status of switches output (Analog pin)
    int statpin = 13;
    // pwmMode - sets the PWM frequency, valid options as follows:
    // pwmMode = 0 will use 980Hz PWM, default mode which will work with all fan types, will cause coil whine if using a MM.
    // pwmMode = 1 will use 4kHz PWM, might reduce coil whine for blowers, use heatsinks on the MM - check MM temp at a low fan speed.
    // pwmMode = 2 will use 8kHz PWM, might be OK for blowers with active cooling on the MM - check MM temp at a low fan speed.
    // pwmMode = 3 will use 31kHz PWM, use with caution - not for blowers with MM as it will cause very high temps. Check MM temp at a low fan speed.
    // server fans - should be able to use pwmMode = 2 or 3. If you are using the PWM control on the server fan, leave this at default 0.
    // if you have blowers with a monster moto, try pwmMode = 1 or 2 and check whether your monster moto temp at low speeds.
    int pwmMode = 1; // value of 0, 1, 2 or 3 - modes 2 and 3 will overheat a Monster Moto if used with blowers
    int Speed = 0;
    int bufferArray[4];
    int whichFan = BOTH;
    void setup()
      Serial.begin(9600);
      // initialize digital pins as outputs
      for (int i=0; i<2; i++)
        pinMode(inApin[i], OUTPUT);
        pinMode(inBpin[i], OUTPUT);
        pinMode(pwmpin[i], OUTPUT);
        digitalWrite(inApin[i], LOW);
        digitalWrite(inBpin[i], LOW);
      // disable timer0's interrupt handler - this will disable Arduino's time keeping functions such as delay()
      TIMSK0 &= B11111110;
      if (pwmMode == 1)
        // Set pins 5 & 6 to Phase-correct PWM of 3.9 kHz (prescale factor of 8)
        TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00); // phase-correct PWM
        TCCR0B = _BV(CS01); // prescaler of 8, gives frequency 61kHz/8/2 = 3.9kHz
      else if (pwmMode == 2)
        // Set pins 5 & 6 to Fast PWM of 7.8 kHz (prescale factor of 8)
        TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM01) | _BV(WGM00); // fast PWM
        TCCR0B = _BV(CS01); // prescaler of 8, gives frequency 61kHz/8 = 7.8kHz
      else if (pwmMode == 3)
        // Set pins 5 & 6 to Phase-correct PWM of 31.25 kHz (prescale factor of 1)
        TCCR0B = _BV(CS00); // prescaler of 1, gives frequency 61kHz/1/2 = 31.25kHz
      else
        // Set pins 5 & 6 to Fast PWM of 980Hz (prescale factor of 64)
        TCCR0B = _BV(CS01) | _BV(CS00); // prescaler of 64, gives frequency 61kHz/64 = 980Hz
      // Just throw on a low speed in case no wind support in application...
      motorGo(0, CW, IDLESPEED); //Motor1
      motorGo(1, CW, IDLESPEED); //Motor2
    void loop()
      ReadData();
      if (whichFan == BOTH)
        motorGo(0, CW, Speed); //Motor1
        motorGo(1, CW, Speed); //Motor2
        if (Speed == 0) motorOff(0);
        if (Speed == 0) motorOff(1);
      if (whichFan == LEFT)
        else if (Speed < 127) then 127 - becomes 0 -255 CCW
      if (whichFan == RIGHT)
    void motorOff(int motor)
      // Initialize braked
    void motorGo(uint8_t motor, uint8_t direct, uint8_t Speed)
      if (motor <= 1)
        if (direct <=4)
          // Set inA[motor]
          if (direct <=1)
            digitalWrite(inApin[motor], HIGH);
          else
            digitalWrite(inApin[motor], LOW);
          // Set inB[motor]
          if ((direct==0)||(direct==2))
            digitalWrite(inBpin[motor], HIGH);
          else
            digitalWrite(inBpin[motor], LOW);
            analogWrite(pwmpin[motor], Speed);
    void ReadData()
      // We need 4 characters - the command followed by three digits
      bool haveCommand = FALSE;
      bool haveStart = FALSE;
      while (haveCommand == FALSE) // can't exit until have a full valid cddd command
        // where c is a valid char and ddd is a valid 3
        // character representation of three digits
        // Valid command always starts with an S (legacy for both fans), L (left fan), or R (right fan)
        while (haveStart == FALSE)
          while (Serial.available() == 0); // spin and wait for data
          bufferArray[0] = Serial.read(); // have data, read it
          if (bufferArray[0] == 'S') //S
            whichFan = BOTH;
            haveStart = TRUE;
          else if (bufferArray[0] == 'L') //L
            whichFan = LEFT;
            haveStart = TRUE;
          else if (bufferArray[0] == 'R') //R
            whichFan = RIGHT;
            haveStart = TRUE;
        // Now need the numbers - will just read three and throw them away if any don't qualify
        // if we unsynchronize, it will fail valid digits and go back to waiting for command char
        for (int i = 1; i < 4; i++) // read and label each byte.
          while (Serial.available() == 0); // spin and wait for each character to arrive
          bufferArray[i] = Serial.read(); // store as they come in
        // Check the numbers for validity
        if (isDigit(bufferArray[1]) && isDigit(bufferArray[2]) && isDigit(bufferArray[3]))
          // all are numbers - have a full cddd command
          haveCommand = TRUE; // otherwise start over looking for a new and valid command
        // Now turn that into a number and clip to 255 - rely on Game Dash for proper scaling
        Speed = ((bufferArray[1]-48)*100) + ((bufferArray[2]-48)*10) + ((bufferArray[3]-48)*1);
        //Serial.println(SpeedGameDash);
        if (Speed > 255)
          Speed = 255;
  2. Trigen
    2,872Coins
    I got things working in Torque mode and done some testing. At the moment the servo drive does not react until about 4-5v input and im unsure why, Could it be the PWM frequency? Im using a Adafruit motor shield and it has a max of 1600hz
    Its also somewhat unstable even though the voltage is the same
    Temp code
    Code:
    #include <Wire.h>
    #include <Adafruit_MotorShield.h>
    Adafruit_MotorShield AFMS = Adafruit_MotorShield();
    // Enable adfruit motors.
    Adafruit_DCMotor *myMotor1= AFMS.getMotor(1);
    Adafruit_DCMotor *myMotor2= AFMS.getMotor(2);
    Adafruit_DCMotor *myMotor3= AFMS.getMotor(3);
    Adafruit_DCMotor *myMotor4= AFMS.getMotor(4);
    int bufferArray[4];
    int motors = 4;
    void setup() {
      // put your setup code here, to run once:
      Serial.begin(115200);           // set up Serial library at 9600 bps
      Serial.println("Adafruit Motorshield v2 - DC Motor test!");
     // AFMS.begin();  // create with the default frequency 1.6KHz
      AFMS.begin(1600);  // OR with a different frequency, say 1KHz
      // set the speed to start, from 0 (off) to 255 (max speed, Turn on M1
      myMotor1->setSpeed(0);
      myMotor1->run(FORWARD);
      myMotor1->run(RELEASE);
      myMotor2->setSpeed(0);
      myMotor2->run(RELEASE);
      myMotor3->setSpeed(0);
      myMotor3->run(RELEASE);
      myMotor4->setSpeed(0);
      myMotor4->run(RELEASE);
    void loop() {
      // put your main code here, to run repeatedly:
       while (Serial.available())
        unsigned int Speed = Serial.read()  ; // Dont need -48, Mover compensates // divide by 4 to get 8 bit
         //myMotor1->setSpeed(Speed);
          //  myMotor1->run(FORWARD);
        //Serial.println (Speed)
        if (Speed > 128){
            Speed = map(Speed, 0, 128, 0, 255);
           // Serial.println (Speed);
        else if (Speed < 126){
            Speed = map(Speed, 0, 126, 255, 0);
            myMotor1->run(BACKWARD);
         else {
         //   motorOff ();
    void motorOff()
        //intialize brake
        for (int i = 0; i <= motors; i++) {
  3. BlazinH
    16,671Coins
    You may need RC low-pass filters on the motor controller outputs for stabilization. Also you may be able to omit the motor controller and just use -5 to 5v. With 600w motors 50% power should give enough torque to move your head around. In that case put the RC filters on the PWM outputs.
