  4. All new posts and threads should be written in English. Please do not create dual posts in other languages. If you are not a master of the English language you can use an external service to create a translation of your words, for instance, Google translate or DeepL.
    Due to low activity, we've also closed the french section.
Seattime's Sims
Discussion in 'DIY Motion Simulator Projects' started by SeatTime, Mar 8, 2018.
  1. BlazinH
    15,508Coins
    When designing elements of a g-seat the ? one should ask themselves is cause or effect. I contend that while simulating effect is somewhat effective it is the weaker of the two. Since g's are just forces without motion, simulating cause whenever possible should be the functionality of a "real" g-seat. Therefore you use the same muscle groups that you do in RL while attempting to counter them instead of the seat actually assisting you in righting yourself. I can tell you it feels absolutely awesome in comparison and also spot on when used in conjunction with a motion rig.
  2. dododge
    dododge Member Gold Contributor
    829Coins
    For those who haven't tried it, that's essentially the approach the Geko design takes -- you're meant to actively fight against its movements and try to keep the seat centered, rather than let it move you around. Its actuators aren't even positional, they just apply a directional force. If you don't fight them the seat-back will keep moving until it bangs into a physical limiter.
    A downside is that it makes you work and you can't just lean back in the seat and relax when you feel like it. There's also a bit of a training period to get used to the design.
  3. SeatTime
    Newcastle Australia
    27,246Coins
    Testing continues for my new G seat setup. Still playing with materials (mylar sheet at the bottom - different densities of rubber and foam at the top), but the current setup is gripping my upper torso quite well and it is great not having to get kitted up to jump into the sim. Still some work to do, but I am quite happy with the current progress. Just working on the sway at the moment, but the panel has been built to move backwards and forwards for surge when I get to that. Was able to use all my current Boden cable setup, so it has been very easy to implement.
  4. SeatTime
    Newcastle Australia
    27,246Coins
    Now added surge (mechanics behind seat) and the harness, very impressed with how this is progressing.
  5. SeatTime
    Newcastle Australia
    27,246Coins
    Testing with NL2 and found if I hold on to the side of the sim with both hands, as you would hold onto a cars steering wheel, or aircraft controls, then it just feels amazing :). All the cockpit to body extended motion cues/forces are there, amplifying the 6DOFs movements.
  6. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    4,238Coins
    SeatTime, I know it's possible you don't want to give too much info but with all the changes it gets pretty confusing. Might you be able to give your current (or recommended) setup in a list format?
    i.e.-
    6DOF using small angles, large heave, sway/traction loss
    Harness tensioner for shoulders and lap
    G-seat with sway/surge back panel, sway side panels, heave bottom panel
    Helmet sway and surge
    etc. etc.
    I'm slowly mentally preparing myself for my second build and it's very important I not waste any more money than necessary on any more failed experiments so this could be hugely beneficial. I need to get it right this time, and I know the key is the G-systems especially.
    I'm also hoping that by relying heavily on a G-seat and other G-systems I can reduce the 6DOF motion to the point where there is no need for motion compensation.
    Thanks for whatever you are comfortable sharing!
    Trip
  7. SeatTime
    Newcastle Australia
    27,246Coins
    I don't think there is a 'perfect' system out there, but I'm getting close. Still trying out some new ideas, so not finished yet (is it ever :rolleyes:) - but tracking along fine. :).
  8. Trip Rodriguez
    4,238Coins
    LOL OK then, I guess it's all top secret. =D
  9. SeatTime
    Newcastle Australia
    27,246Coins
    Really...
  10. SeatTime
    Newcastle Australia
    27,246Coins
    There are photos, so not too top secret :). I have been active on this site since 2013 and it has never been my intention to tell people how to do things, as if I know it all :rolleyes:, nor is there any guarantee that what ever I am working on at the time is the 'final' best solution - often subjective. I just post what I may be working on and if someone can get ideas off it then good. Sorry if I offended you. There are of course some things that I do not post about, but that is my choice as a possible commercial decision - I owe no one here anything.
  11. Trip Rodriguez
    4,238Coins
    LOL I'm just teasing you man, you've got how many posts and photos here?
  12. Trip Rodriguez
    4,238Coins
    And now the page refreshed when I posted my reply and I see your second reply.
    My apologies SeatTime, I thought the "=D" which to the best of my knowledge is a big grin would be enough for everyone to realize I wasn't serious. I'd say "how could I be?" because stating that it's "all top secret" is ludicrous given the existence of this thread and all your posts, but this is the internet and people make ludicrously stupid angry posts all the time.
    If you look at my post up there it's never been edited and you will see the 'big grin" emote, that's my evidence!
    Thanks for sharing what you have, reading this thread totally changed the approach I'm going to take with the G-Seat.
  13. SeatTime
    Newcastle Australia
    27,246Coins
    My bad, the internet is a great thing and 'D' has a different meaning in my part of the world. Too use to seeing a real emoji and it would not be the first time someone has had a go at me on this site. All good :).
  14. SeatTime
    Newcastle Australia
    27,246Coins
    The G-seat continues to evolve.
    I have now added some side paddles to the seat which operate in a parasitic fashion.
    There is a arm (may end up with two) which is attached to each paddle and as the seat back moves back for acceleration the arms push the paddles forward the same as the GS5 seat, but in this case the whole back of the seat has also moved backwards and of course forwards for braking were the side paddles drop back.
    For sway, when the seat back moves left the left paddle arm rides up the side of the capsule seat and pushes just the left paddle forward as a GS5 seat would. When the seat moves right the right paddle roller rides up the capsule seat and pushes just the right paddle forward.
    Normally to get this sort of capability (Ie sway and surge) out of paddles you would need to drive them independently with their own motor etc.
    This is all coming together nicely :).
    Some pictures below, although it does not show it that well.
    Seat at center position
    Seat swaying right
    Seat accelerating
    • Like Like x 5
  15. OZHEAT
    OZHEAT Member
    Australia
    1,902Coins
    3DOF, DC motor
    For a long time I've envisioned something similar but the main difference being not linear movement but more radial with the pivot point being very near the lower back/posterior.
    The use of a stiff spring at the top would also allow you to lean in to a turn just like in real life, it more about tension than movement as the sides of the seat would limit movement.
  16. SeatTime
    Newcastle Australia
    27,246Coins
    What your not seeing is how a body reacts to the movements of this seat when your hands are on a steering wheel, flight stick or even just holding onto the sides of the capsule and don't forget there is a 6DOF doing its thing as well - There is your tension, with the paddles just adding in some more pressure in the right places :).
  17. SeatTime
    Newcastle Australia
    27,246Coins
    Also the movement of the upper body ends up being quite radial in this seat, as it really cannot do much else and its why there is a mylar sheet at the base.
  18. OZHEAT
    OZHEAT Member
    Australia
    1,902Coins
    3DOF, DC motor
    Fair enough, i've never been inside a real racing car or fighter jet as I've never experienced my right or left shoulder lunging forward as I go through a turn, nor have I experienced a seat harness tightening on me as I accelerate.
    cheers anyway
  19. SeatTime
    Newcastle Australia
    27,246Coins
    Just for information nothing on my setup makes my right or left shoulder lunge forward - it just does not work that way, nor does a harness tighten when a car sim accelerates - the opposite actually. Maybe one day build a sim and see how all this really works. Not hating, we all cannot be in a position to build a sim. Anyway - All the best.
  20. Trip Rodriguez
    4,238Coins
    Ozheat, I don't know for certain if you were intentionally abrasive there or if it just came across that way but I suggest you edit that post to something more politely worded.
    I will respond anyway, doing my english to english translation thing.
    SeatTime and BlazinH have both stated in this thread that, when possible, it's better to move the driver against the seat than it is to have the seat apply pressure to the driver. This much more closely matches reality.
    In a forward acceleration a normal G-seat would simply push forward against the driver's back to simulate the pressure of being pushed back in your seat. The thing is that the actual movement of the driver is opposite what it should be. I believe that SeatTime's design here is meant to allow the driver to actually move backward into the seat like he would in the real world, while still applying forward force with the paddles to simulate the pressure of being pressed back into the seat. Pretty ingenious if it works.
    The big question in my mind is how to accomplish a really good cue in this manner for deceleration (negative acceleration) aside from just tightening the harness. It seems to me like moving that back panel forward to move the driver forward in the seat would still feel like a positive acceleration cue because of the feeling of pressure on the driver's back.
