Seattime's Sims
Discussion in 'DIY Motion Simulator Projects' started by SeatTime, Mar 8, 2018.
  1. Pierre Lalancette
    3D teacher
    Quebec, Canada
    6,937Coins
    Thanks. Yes, of course, this is not the final distance they will travel, but the distance they can. I don't think mine CAN travel that distance and I really wonder why. Anyway, I have other things to worry about, like communicating with the game... Anyway, thanks again for the info. I'm back to simtool documentation.
  2. Erik Green
    Erik Green Member
    253Coins
    Have you seen any wear on the carbon actuator tubes?
  3. SeatTime
    Newcastle Australia
    28,605Coins
    AC motor, Arduino, Motion platform, 6DOF
    Been a while since I have posted here as I have been so busy with other projects. Latest is that I have been having issues with my old 1280 USB controller (the new 1280 USB works fine) card which often seem to have a mind of its own, with some actuators pulsing and vibrating with noise when connected to game or simtools data (no issues when they are not receiving data) note - all firmware etc is up to date. Have now ordered three Arduinos which I will wire into a module that can be plugged into my rig and replace this 1280. Just putting this out there for information only.
  4. Pierre Lalancette
    3D teacher
    Quebec, Canada
    6,937Coins
    Glad to see you around.
    Working on my carbon fiber platform, I'm wondering all the time will it be strong enough. Then I'm telling myself, Seattime did it. So, I convince myself to keep on on it (so I can fail with dignity).
  5. SeatTime
    Newcastle Australia
    28,605Coins
    I have a long background of working with fiberglass - building fiberglass moulds etc for my various hobbies since my teens. Moving onto Carbon fibre was therefore not such a jump. I wish you all the best, although I feel you have really thrown yourself into the deep end for your first carbon fibre project :) with the forces involved in a motion rig. That 3M expoxy should not be supporting any weight only by itself. Some examples of some of my high stress carbon rig parts below.
    Image below of my Rear and front crossmember main support bonded/bolted to the fiberglass cockpit - single moulded piece cured under high vacuum, with solid carbon plate and rods embedded into the moulds.
    Main front crossmember 'Cradle'
  6. Pierre Lalancette
    3D teacher
    Quebec, Canada
    6,937Coins
    In deed, I am in deep... ends.
    Playing safe was never good for me. Let's hope I learn to swim fast.
  7. SeatTime
    Newcastle Australia
    28,605Coins
    Finally went back to three Arduinos driving the 6DOF, as the old 1280 was acting erratically when receiving data. Everything is now working as it use to using the new Simtools Linear Hexapod plug-in. New 1280 is still driving part of the G -systems.
  8. SeatTime
    Newcastle Australia
    28,605Coins
    With everything working fine, I have started to design a new sim capsule :rolleyes: (will be still using the 6DOF actuators ) - I do love the design/building process.:D It's mainly to improve access, as I and certainly my friends are not getting any younger :) and it can be a bit skinny to sit in for some with the HOTAS fitted. While I'm at it decided to improved weight and allow the fitment of a few new G system functions. Will incorporate all I have learned over the years in regard to access and simulation function. It will be very light - full carbon fibre frame with a integrated carbon fibre multi-movement G-paddle 'cradle' and harness system built into the capsule - Ie a standard seat will not be used. It will be built as a completely new capsule, so that it will just bolt up to the actuators - Stay tuned, this should be interesting :).
    • Like Like x 6
    122,616Coins
    I always look forward to your innovative upgrades, they are truly ingenious in pushing the DIY motion sim envelope!
    • Agree Agree x 3
  10. SeatTime
    Newcastle Australia
    28,605Coins
    Decided to start by build a 3D printed scale model of the rig - as carbon fibre is not cheap. It's a great way to better visualise how things will go together and hopefully catch any design issues.
    This will be the main backbone:
  11. Pierre Lalancette
    3D teacher
    Quebec, Canada
    6,937Coins
    You are not printing full scale, are you?
  12. SeatTime
    Newcastle Australia
    28,605Coins
    Not necessary and I could not do it anyway - 10th scale. Its been good to have a look at it in the flesh, as I have now changed the design. It is always quite a iterative process.
  13. Pierre Lalancette
    3D teacher
    Quebec, Canada
    6,937Coins
    I could not agree more. Doing mine was 1 hour of gluing followed by 3 hours of contemplation to figured out what would be the next part. It's almost done, but I have not yet dare to sit on it. It does look really strong, as I was not cheap on my cheap glue. I have almost finish the second big tube of it. I'll try it the day I will do my 600 km back home... one day.
  14. SeatTime
    Newcastle Australia
    28,605Coins
    New Backbone design:
  15. SeatTime
    Newcastle Australia
    28,605Coins
    By adding some pultruded tubes/rods to increase the stiffness, have simplified the design to this:
  16. SeatTime
    Newcastle Australia
    28,605Coins
    Just ordered in parts to build a new G seat. FI. In part it will have multi-movement panels in the seat. They will be able to move left/right - for sway and the back will be also hinged at the bottom so it can move forward/back for surge. This will of course be integrated with a full harness system.
  17. MarkusB
    MarkusB Active Member Gold Contributor
    4,013Coins
    This is an interesting approach, which I am also thinking about for some time, especially regarding the forth/back movement of the backrest.
    (You know I had a backrest that was able to move up/down for supporting the heave force.)
    About the sideways movement of the backrest: Here I see two possible effects, depending on whether your torso is fixed to the moving part of the backrest or not:
    1. Torso is not fixed/strapped to the moving part of the backrest: If the backrest moves to the right, the friction against your torso may cause the impression that your torso is pulled to the left.
    2. Torso is fixed/strapped to the moving part of the backrest: In this case, your torso will follow the backrest movements. That means, when the backrest moves to the right, your torso does the same. This is what the Gecko G-Seat does. See this video at 00:45. Will this also be your approach, as you wrote that you will still use a full harness system?
    About the back/forth movement of the backrest, which I am also evaluating:
    What do you think: Will a backwards movement simulate positive or negative surge force? On the one hand, your torso goes backwards (which it also does when accelerating), but on the other hand the pressure of the backrest against your torso may release (which is does when braking).
    In any case I am looking forward to your results.
  18. SeatTime
    Newcastle Australia
    28,605Coins
    The devil is in the detail, it is not as simple as it may look - the panels flex (they don't stay flat) and the angle of the seat is important ;). It has some features of the Gecko, but is not the same. I like my G-vest, but it won't fit on my new sim, nor does it cater easily for different sized users, so this will be the replacement.
  19. SeatTime
    Newcastle Australia
    28,605Coins
    So, why not just use the usual paddle setup like a GS-5? Well I have tried paddles and they are OK, but don't feel as good as my Vest, as I like the movement it gives to my torso and the small differential to the controls (steering wheel pedals etc) as you would have in real life. So this is basically a merging of the two systems.
  20. BiT0
    BiT0 Member
    222Coins
    Speculating about a G-seat myseslf was evaluating alternative to the usual paddle setup.
    I am considering sliding panels for sway too. Another idea I am evaluating is that the sliding panel is not indeed the one where I sit but an underling one moving the sides of the seat toward the body.
    While losing the feeling of the column deformation it may allow to move less weight.
    What do you think?
