SCN5's not detected by Force-Profiler
Discussion in 'SimTools compatible interfaces' started by fsutton, Apr 28, 2011.
  1. fsutton
    fsutton Member
    323Coins
    Hello All,
    I'm converting my FREX simconmotion to x-sim. I ordered two devantech usb-485 converters. I'm using the original power supply from FREX which has the kill switch. I've hooked up the FREX green wire to +ve the white wire to -ve and the black wire to ground. the devantechs are assigned to com2 and 4. I can see lights flashing on the devices when I start the force-profiler software, but the scn's are not showing up in the output box. I'm not sure what the problem is.
  2. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    try inverting the white and green wires ... worked for me when I used this adapter...
    Bleco
  3. fsutton
    fsutton Member
    323Coins
    I'll try this tonight. Thank you very much for the reply.
  4. fsutton
    fsutton Member
    323Coins
    Thanks Bleco. Reversing the wires did the trick. Now to solve the force-sender issue over in the software section. Have a great weekend.
