Question SCN5 strange behaviour
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Tonantsa, May 24, 2018.
  1. Tonantsa
    Tonantsa New Member
    Finland
    81Coins
    SCN5
    SCN5 works fine when I turn the power on and start Simtools or Dyadic TBVST. I can test the actuator with Game Engine output testing and it works fine.
    If I close Simtools or TBVST and start it again, SCN doesn't work anymore. TBVST says it cannot communicate with COM port. Only way to make it work again, is to close the program and turn the power off and then again on. Then I can start the program and it works fine again.
    COM port seems to be reseting or SCN stops sending data? Wiring and actuator must be fine because nevertheless they work sometimes. What can I do?
    150,776Coins
    +11,021 / 55 / -2
    Just to clarify, two programs can't use the same com port at the same time, so it sounds like it works when one program has exclusive use of the com port, is that right?
