samet burak's questions
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by samet burak, Nov 10, 2020.
  1. samet burak
    samet burak Member
    - 39Coins
    Friends drit 2.0 rally axis Do you adjust as a photo, please
  2. Ads Master
    Ads Master
  3. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    375Coins
    2DOF, DC motor, SimforceGT
    These are my configurations, but it depends a lot on your simulator, not all of us have the same structures ..... I have engines with 6-centimeter cranks which rise 40% and I like the result because there are layers that voice a 40 is little and you would have to add or lower than 40%, it depends a lot on the simu of each one. 20201028_194814.jpg
    115,446Coins
  5. samet burak
    samet burak Member
    - 39Coins
    City Car Driving patch discount but why doesn't it work?
    115,446Coins
  7. Sam Neall
    Sam Neall Member
    8Coins
    I would suggest using a base profile like the one moaale posted then fine tuning it. I found that it really depends on the maximum and minimum range of your simulators motors.
  8. samet burak
    samet burak Member
    - 39Coins
    Friends How to adjust softer shake simtools reacts very harshly
  9. samet burak
    samet burak Member
    - 39Coins
    [QUOTE = "Sam Neall, gönderi: 209324, üye: 33528"] Gönderilen moaale gibi bir temel profil kullanmanızı ve ardından ince ayar yapmanızı öneririm. Simülatör motorlarınızın maksimum ve minimum aralığına gerçekten bağlı olduğunu buldum. [/ QUOTE]
    DenemekI'll see if you'll be all right.
  10. samet burak
    samet burak Member
    - 39Coins
    Motors How can they work softer, where can I throw up their power, simtolls?
  11. RacingMat
    19,092Coins
    hi!
    please be more specific and detailed! How can we help you without knowing your rig (2DOF, 6DOF, SFX ...), your motors (RC servos, wipers, AC motors...) or your setup of Simtools.
  12. samet burak
    samet burak Member
    - 39Coins
    I use the 24 volt disabled motor with a 12 volt 40 amp power supply. I have ibt2 with your ino file 2 pieces
