Saitek pro flight Need wiring info
Discussion in 'Electronic and hardware generally' started by Wagnard, Feb 4, 2018.
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,030Coins
    I wanted to know if someone have a wiring diagram or simpling a screenshot of the 10 pins socket of the display of the yoke.
    Reason: found a used Saitek pro flight yoke but the display was not working, I opened it up and I saw the the 10 pin socket was "destroyed" and all wire was laying around.
    Thanks for the help
    Edit: I managed to found the answer. The pins wires colors are the same as the other 10 pins inside that part of the yoke.
