sabertooth 2x32 /2x60 batteries alternative?
Discussion in 'Electronic and hardware generally' started by Wagnard, May 21, 2017.
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,020Coins
    As the subjet say, is there an alternative for the 12v batterie required for the regenerative current from the sabertooth?
    It is quite annoying to have heavy batteries like these on the simulator.
    I heard of voltage clamp resistors, anyone tried?
  2. Pit
    30,472Coins
    I never had any issues with regenerative current, i use PSUs only. Though tested a Diode years ago for testing purposes, it works ;). But beware the specs of the Diode (max. current), it will be blown away in no time if too weak.
  3. BlazinH
    16,650Coins
    When using 2x60's a battery is recommended more to assure there is enough available current than for regenerative purposes but a battery is not always needed. Not as big of a deal on 2x32's that are easier to power.
  4. Wagnard
    Wagnardsoft
    5,020Coins
    I also heard hat If I do not use a battery, than it is possible that it will be the motor eating the regenerative current and it could heat up the motor.
    I guess i'll have to test (when/if) I get one.
    Thanks for your knowledge everyone.
  5. SilentChill
    20,581Coins
    The sabertooths 2x32's come supplied with resistors to take the regenerative current so you don't need a battery, however with the 2x60's you will need a battery as BlazinH says for the extra Amp's and also the regen current.
  6. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    If I remember correctly, you changed your server psus for led psus because the regenerative current tripped out your psus constantly, same is happening to me, and the resistors that same with the sabertooth are not helping much, did you tried using a battery instead before changing the psus? I'm using 24v and it is not easy to get big enough 24v psus here.
  7. SilentChill
    20,581Coins
    I could not stop them tripping out even with a battery so I got the new LED PSU's never had a problem since
  8. Evan Rowlands
    Evan Rowlands EMR Industries
    business owner/ EMR industries
    Melbourne Australia
    - 82Coins
    im not running anything just a 12volt 30amp power supply could this explain the shaking of one motor after half an hours use ? even with the pc off it still shakes
  9. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Hallo can you please show me wich l'ex psu you use? I need one For my sabertooth 2x32 and 90zyt motors 23A 40A peak 12v
    Why you choose led psu instead server psu?
