Riton' 6DOF with AC gearhead motors
Discussion in 'DIY Motion Simulator Projects' started by riton, Jun 22, 2020.
  1. riton
    riton Active Member
    1,006Coins
    Hi everybody!
    I started here and even before Simtools for a long time with a 2dof simulator. it still gives me a lot of pleasure! I love this simulator!
    but it's time to move on to more serious things!
    this project is started. I gathered all the elements: the motors, the sensors, the frequency converters .... I recovered all the elements of the @vulbas simulator.
    https://www.xsimulator.net/community/threads/my-6dof-reproduction-of-ckas.5359/page-10#post-84712
    I self-trained at Fusion 360 for the drawing, be nice! 15 days ago I did not know at all! I also have a 3 D printer for manufacturing and improving parts.
    I post my work in Youtube:
    https://www.youtube.com/playlist?list=PLzgqQ7DQsR4NrnBAgGOfFyARz5eJqnsyI
    Motors: 6x MV 173 / 71 C 4 / 14 tr/mn
    0,55 kw. 1500 tr/mn. 230/400 V. IP 55. Cl F.
    Reductor 1/99,21
    Speed out : 14 tr/mn / 347 Nm
    Variator frequency:
    6 x YASKAWA J1000 3 Phase + 6 resistors
    Electronics : Thanos AMC
    6x ENCODER ABS MAGNETIC 12-BIT 6MM - AEAT-6012-A06
    for the characteristics:
    23 cm crank, 120 ° movement angle to optimize the linearity of the crank movement.
    motor speed at 20 rpm, adjusted with drivers movement
    speed 400 mm Second , heave +/- 200 mm
    you can quickly see my work here:
    https://www.instagram.com/p/CBsuIePoGmN/?igshid=2kyvxuq5rv0s
  2. riton
    riton Active Member
    1,006Coins
    news, cockpit modifications :
