Question Raspberry Pi Pico communication with simtools
Discussion in 'SimTools compatible interfaces' started by Spart, Dec 29, 2021.
  1. Spart
    Spart Member
    Student
    Kauno kaimas
    229Coins
    DC motor, Arduino
    First of all, I am new to programming. I am trying to write code (in C++) that will allow Pi Pico to receive data over usb/uart (I found usb serial connection not working quite right so I am using usb to ttl adapter for communication) from SimTools. The problem I have is when I test my code manually by sending values over terminal (putty) it works just fine, it reads numbers that I wrote and converts them into integers and echoes it back, but once I try receiving data from SimTools, I see no data being sent and no data echoes back (I am using to usb to ttl converters to see what's happening). I configured simtools to send decimal data so its easier (atleast for me) to use it.
    For reading the data I am using non blocking version of getchar_timeout_us(0) but I am wondering if thats the problem and I should use something else. If I send data simtools data from one usb to ttl adapter to another it works just fine.
    Code:
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #include "pico/stdlib.h"
    #define ENDSTDIN    255
    #define CR        13
    int main() {
        stdio_init_all();
        bool onoff = 0;
        const uint LED_PIN = 25;
        char strg[24]; // how much characters are expected minus one
        char pirmas[5];
        char antras[5];
        char trecias[5];
        char ketvirtas[5];
        char penktas[5];
        char chr;
        char narys;
        int lp = 0;
        int x = 0;
        int y = 0;
        int z = 0;
        int xx=0;
        int yy=0;
        memset(strg, 0, sizeof(strg));
        gpio_init(LED_PIN);
        gpio_set_dir(LED_PIN, GPIO_OUT);
        while (true) {
            chr = getchar_timeout_us(0);
            while(chr != ENDSTDIN)
                strg[lp++] = chr;          //start collecting input char one by one
                if(chr == CR || lp == (sizeof(strg) - 1)) //checks if all data is collected
                    memcpy(pirmas, strg, 4 );
                    memcpy(antras, &strg[4], 4 );
                    memcpy(trecias, &strg[8], 4 );
                    memcpy(ketvirtas, &strg[12], 4 );
                    memcpy(penktas, &strg[16], 4 );
                    narys = strg[20];
                    printf("You wrote - %c\n", narys);
                    strg[lp] = 0;    //terminate string
                    x =  atoi (pirmas);
                    y =  atoi (antras);
                    z =  atoi (trecias);
                    xx =  atoi (ketvirtas);
                    yy =  atoi (penktas);
                    printf("You wrote - %d\n", x);
                    printf("You wrote - %d\n", y);
                    printf("You wrote - %d\n", z);
                    printf("You wrote - %d\n", xx);
                    printf("You wrote - %d\n", yy);
                    //memset(strg, 0, sizeof(strg));
                    lp = 0;        //reset string buffer pointer
                    break;
            gpio_put(LED_PIN, onoff);
            onoff = !onoff;
            sleep_ms(1);
        return 0;
    In my case I am trying to read data for five axis.
  2. yobuddy
    51,377Coins
    Can you show me what you sending for your test thru putty?
    Also, will you show me how you have SimTools configured for output.
    From this I may be able to see what the problem may be.
    Take care,
  3. Spart
    Spart Member
    Student
    Kauno kaimas
    229Coins
    DC motor, Arduino
    Hey, thanks for reply, I already sorted the problem out, now it works as intended.
