RAsbery Pi3 & Sim & arduino
Discussion in 'SimTools compatible interfaces' started by ferrere, Apr 17, 2020.
  1. ferrere
    ferrere GADOY 63450
    engineer ( PLC )
    Saint Sandoux
    4Coins
    Hello
    I want to install in my chassis 2 DOF, a SIMTOOLS on raspberryPI3 and windows (everything is on SSD).
    can you tell me if this is possible?
    the goal being to have an ethernet link with the gaming pc and a usb link with the arduino UNO R3.
    thank you in advance.
    Bonjour
    je souhaite installer dans mon châssis 2 DOF , un SIMTOOLS sur raspberry PI3 and windows (le tout est sur SSD) pouvez vous me dire si cela est possible ?
    le but etant d'avoir une liaiosn ethernet avec le pc de jeu et une liaison usb avec l'arduino UNO R3.
    par avance merci
    153,065Coins
    +11,117 / 56 / -2
    SimToolswould need to be installed on a small form factor PC, as it is a Windows X86 application, which I don't believe a raspberryPI3 can run.
  3. Pit
    30,503Coins
    I suggest "Try and Error". 32-Bit limited, emulated when running x86 software but theoretically possible - on the other hand if it satisfyingly works is another story . But you never know, if you like tinkering why not giving it a try? :)
  4. ferrere
    ferrere GADOY 63450
    engineer ( PLC )
    Saint Sandoux
    4Coins
    Noorbeast and Pit Thank you very much for your answers.
    Too bad for PI3.
    merci beaucoup
