R Factor Frame Rate Problem - Quad Core
Discussion in 'Off Topic - All other stuff here' started by Fahim, Mar 2, 2009.
  1. Fahim
    Fahim Member
    307Coins
    Dear Sirs,
    I have new pc from Argos:
    2.5ghz Quad Core
    3GB Ram
    Nvidia 9800 I think.
    The R Factor used to run great until I decided I wanted to up the resolution and run at 1920 x 1080. 1080P.
    I then found that it jerked which I find silly because my machine is powerful but the game does not probably recognise the quad cores.
    I then went into nvidea control panel and had to DECREASE settings:
    I changed Anti Aliasing from X8Q. I changed it to just X8
    Now the frame rate is smooth but there is some jaggy lines. There is a rfactor frame rate fix which you can find from google. It is supposed to increase frame rate. Has anyone used it. Its from a guy called wobster or wobmaster or something.
    Kind Regards.
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Do NOT use this fix!!! Please try the suggestions that I sent in response to your PM.
    -Disable VSync in rFactor Config
    -Anti Aliasing to X2 in rFactor Config
    -Leave default nVidia 3D settings alone for now
    Press CTRL-F while driving rFactor and report back your frame right that will be displayed in the top right corner of your screen.
  3. Michael G. Hughes
    Michael G. Hughes New Member
    United States
    58Coins
    2DOF, 3DOF
    You should focus on the following points that will help you to solve frame rate problems
    1. Close background processes.
    2. Update the game.
    3. Update your graphics drivers.
    4. Search for player tweaks and mods
    5. Repair your installation.
    Would you like to check the frame rate for your pc then you can pick the top FPS Checker
