Questions about 80ST Servo Motors amperage draw
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Moe Colontonio, Dec 23, 2025.
  1. Moe Colontonio
    New Jersey USA
    818Coins
    I'm getting ready to build another SFX100 based 4dof rig using 80ST servo motors. I'll have 4 motors for roll/pitch/heave, and a 5th motor for traction loss. I'll also have 2x 80ST for the belt tensioner for a total of 7x 80ST motors.
    I can run them on 240v or 110v, it really doesn't matter all that much to me as the sim will be in a hangar with both 30a/240v and 20a/110v available.
    I'm trying to get a straight answer on amperage draw. I'm reading 3a per motor, but I've also seen 9a. My current rig uses 4x 110ST and 1x 80ST on a 30a/240v line with no issues.
    I'm purchasing the belt tensioner from E-Racing Labs, and they advised me to just run it all on a 20a 110v line. Just seems like a lot of motors on a single 20a outlet. Does the Thanos controller offer some kind of protection for low voltage/high amperage draw events?
    TIA
  2. Misanthrop
    Misanthrop Active Member
    814Coins
    You will have no issues with both solutions.
  3. Joe Cortexian
    Joe Cortexian Active Member Gold Contributor
    1,495Coins
    If you have a choice the 220w is safer. 120v 20amp is only 4400w total vs 7200w. I think “it doesn’t matter” is bad advice. Wouldn’t you prefer the I have too much power problem?
    I am running a single 750w servo (drift) off an 800w step up transformer. Very occasionally I get a buss under-voltage alarm which means I have to re-power the amp. I can adjust parameters to get around it but the step up transformer is temporary until I install a 240v breaker.
  4. Misanthrop
    814Coins
    Your problem is the stepup transformer, not the servo itself!
    At an Motionrig there is no time all servos will pull the highest amperage. He will be completely fine with 110V. This is proven many times here in the forum and the community. I am using 7Actuators(80ST), an 23Nm Wheelbase and an PC with 9800X3D and 4090 on the same breaker without any issues at 100V. 3 Servos i am using with an setup transformer at 220V(Surge and 2xTL).
    Only when i use all Actuators with the stepup transformer at 220v it will trigger the Breaker very rarely.
