Projector screen on sim
Discussion in 'Off Topic - All other stuff here' started by bsft, Nov 3, 2015.
  1. bsft
    Hi there. Just curious , at my local Kmart , they have projectors and 84" screens for $299. As its for sim use it would not get used that much for me.
    Question is , my intention would be to curve the screen a bit. Apart from not curving too much , is there a point where it can be curved so as I would not need 2 projectors?
    Cheers
    150,548Coins
    +11,017 / 55 / -2
    There is software that lets you projection map to any surface space. It is more a question of appropriate positioning and resolution.
    A couple of years ago I used 2 powerful projectors to 3D Projection map a while skatepark to turn it into an interactive performance surface for youth performers. The challenge is that all projectors have a limited focal range which must suit what you are doing. Cheaper projectors also tend to have lower resolution. I use an ultra short throw projector with my sim, but that is to compliment the Rift. I would go for a higher end projector if it was my only display.
  3. bsft
    Lower resolution not a problem, its amazing how good 1024 x 768 can look with some in game graphics settings.
    I am not looking for software, I am asking opinions about curve in screen as its only one projector.
    From bits and pieces I have read, a curve is possible, just a matter of field of view range as well.
    Spec say it projects up to 84" , which is heaps more than I am planning. I am probably looking at 55"-60" wide with a slight curve in the screen.
    Playing with motion makes any resolution changes almost negligible I found. My vision is being shaken anyway.
    Ok, I have layby it anyway and will get it in a few weeks, set it up and give it a run.
  4. Pit
    30,472Coins
    @bsft you cannot use curved screens using projectors w/o additional software as @noorbeast has tried to explain.
    As far as you probably know I am using triple screens but they are not curved because the software would unsharp the picture quality. If you would use 4k resolutions then this issue can be neglected. Anyway I play with 1280x720 (3720x720), 1024x768 is too low IMO because if you would like to use big screens you can see every pixel.
  5. bsft
    Ok, thanks @Pit and @noorbeast , I appreciate the help, I will hunt up some software later after I get set up.
    I will see what sort of resolution I car run once I am going, not for a few weeks.
    Cheers.
  6. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Q. Apart from not curving too much , is there a point where it can be curved so as I would not need 2 projectors?
    A. You can curve it to as much as 120-150 degrees but not sure about how much destortion there would be even with corrective software.
    A few yrs back I tried a short throw low res projector and the screen door affect was too noticable for me. I projected it on white metal coil used for trimming exterior homes that I had. I think I used a 2ft x 5ft piece and temporally curved it around to my liking. It was all an experimental set up to see what was involved.
    It definitely gave me more of a feeling of being in a car but there's only so much a single camera can produce as far as total width res. It's not the same as what triples can produce.
    Ultimately the screen door affect was the main reason I put it on the back burner plus what a good 1080p projector and bulb replacement costs. It was all more than what I wanted to invest at that time.
    So experiment and have some fun!
  7. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    Sounds like an interesting idea. At first I'm not mounting any screen or projector on my sim.
    I want to just use my normal TV for starters which is too big to fit on the sim and then I want to evolve to just using the HTC Vive but a short throw projector might be a good mid way point.
  8. soraz
    soraz Member
    Noale VE, Italia
    5,161Coins
  9. Pit
    30,472Coins
  10. bsft
    @soraz , thanks for the info, but as @Pit mentioned, I am NOT going to spend that much on a projector. My entire sim costs less than that.
    @Hobbs77 , I dont plan to curve it much , maybe similar to a curved TV or monitor. It projects 84" , and I am going to use about 55-65" of that amount. So a curved TV is stuff all curve.
    I do recall I can tweak the graphics cfg file of some games to force various custom res, including 3 screen width onto one scree.
    Its cheap and I am sure I can get it to work as a start. I dont expect much from $299, however, I have done some good images with cheap stuff.
    If anyone does know of any "curve projector image software" , (I will do a search once I am closer to set up though), Id appreciate any links. EDIT Surfacemap software, copy, I will look into that.
    Cheers.
