Question Project cars 2 problem
Discussion in 'SimTools Plugins' started by paulopsx2, Sep 22, 2017.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Has anyone have a problem with pc2 plugin?? I put in on simtools, patch game, put options "ON" on shared memory, and point to project cars 1, like instructions. But dont works. Try with project cars 2 too. Its necessary put udp on?
  2. value1
    14,936Coins
    I haven't tested with the final game yet. It worked well with the beta. We'll see…
  3. paulopsx2
    brasil
    647Coins
    Hum... tks... i dont have pre releases... pickup final now on steam. Waiting for more tests.
  4. gabby de buyst
    gabby de buyst New Member
    brussels
    135Coins
    hi, same here.
    tried all mixed setup with ingame settings on project cars 1 and 2 on both options with udp on and off.
    nothing worked.
    I hope there will be a new plugin released
  5. paulopsx2
    brasil
    647Coins
    It works ! After 6 hours and some uploads... tests. Well, first of all, pick up plugin 2.0.3.3 and install. Then, put ONLY shared memory in pc1 ( no udp ). Be sure with firewall rules not block your ports and pc2. Runs pc2 and game manager in admin option. ( in fact, this was my first challenge today... for now, i solved the second: simvibe. No files for pc2 too in simcommander site. Well, i create one rs... finally, i configure my htc vive and some settings on t500rs. now all works fine. Go to sleep a feel hours now. Kkk
  6. gabby de buyst
    brussels
    135Coins
    Now it works but I had to re-install all the thing because simtools didn't work with other simulator either after pcars2. Certainly a bug
  7. paulopsx2
    brasil
    647Coins
    What? Here are normal. Pc2, nls2, asseto, elite dangererous... all its fine.
  8. gabby de buyst
    brussels
    135Coins
    now everything is working fine and nice feelings with pcars 2. Last bug, when I start the game it always asks me "movement of simulator only during playing game" twice.
  9. paulopsx2
    brasil
    647Coins
    Yeap.. for me to.
  10. drazic
    drazic New Member SimAxe Beta Tester Gold Contributor
    - 135Coins
    After adding the plugin, I cannot see "pCars2" in the game combo box (game manager)... so i cannot patch the exe.
    Any tip ?
  11. gabby de buyst
    brussels
    135Coins
    you don't have to patch the game. You have to share game memory in "options" => "system"
  12. value1
    14,936Coins
    Yes, you need to patch the game AND you need to set shared memory in Project CARS2 (pCars1 or pCars2, doesn't matter).
    @drazic: Do you have a DIY or PRO license of SimTools? The demo only allows LiveForSpeed.
  13. drazic
    - 135Coins
    I have a pro license: I use it for iRacing, pCars 1, Assetto Corsa ...
    But as I said, after installing the pCars 2 plugin, it does not appear in the game list... and I dunno how to remove the plugin
    Also tried shared memory (without patching exe) but no motion :(
    Maybe firewall but as you said I need to patch... will try tomorrow
  14. paulopsx2
    brasil
    647Coins
    Working as well here... pc2 is original? From steam?
  15. drazic
    - 135Coins
    Yes from Steam...
    So, someone to tell me all steps ?
    First removing the plugin (as the game does not appear) ?
    Then all steps from those working
  16. gabby de buyst
    brussels
    135Coins
    sorry my bad
  17. drazic
    - 135Coins
    Could this be because I am still running Simtools 1.3 ?
    The process of adding the plugin is ok but I cannot find the dll for pcars2 in users\appdata...
  18. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    299Coins
    Installed with plugin updater, but the game is not listed in in simtools
  19. value1
    14,936Coins
    All the plugins are for Simtools V2 now.
    Is this your (@Javo5) issue too?
  20. drazic
    - 135Coins
    Ok, I hope there is no problem with iRacing plugin
