problem with fan settings
Discussion in 'SimTools compatible interfaces' started by chris62, Feb 15, 2012.
  1. chris62
    chris62 Member
    - 9Coins
    I have built a fan system like here in the forum from splendiddd and frakk. And I added the described settings into the profiler .
    Unfortunately the fans are running permanently during the game. It is probably a problem with the setting in pololu maestro control . Maybe anyone can help me to get the correct settings for the fans. :sos:
    Many thanks
    Chris
  2. Simon_lebel
    Simon_lebel Member
    Levis, Quebec
    157Coins
    2DOF, DC motor, JRK, 4DOF
    I'm working on mine as i speak but my control is good. Post some screenshot of your setup , both meastro settings and profiler+uso and i will help you. Can you control the fan using only the maestro software? What kind of fan are you using? Is it loud? Mine scream as hell :thbd:
  3. chris62
    chris62 Member
    - 9Coins
    Hi Simon,
    thanks for quick response. :rofl:
    i have the same configuration like here in the Forum. I use the two recommended fans and belive me this fans are loud as well. I use the Maestro Controller and the software from the Pololu Homepage. I put my fans in two Boxes with some damping material, so the noise is reduced but it is still loud. I guess I reduced it aprox. 50%.
    Ok, I will send some screenshots to make it more visible
    Best regards
  4. chris62
    chris62 Member
    - 9Coins
    Hi
    it sounds very easy but I can not put any screenshots into my messages. Can anyone help me
    thanks
