Presenting Free Roll / Free Pitch Simulator
Discussion in 'DIY Motion Simulator Projects' started by gsffair, Nov 4, 2010.
  1. gsffair
    gsffair New Member
    - 150Coins
    I would like to show you a simulator we are developing here in Brazil... It doesn't have a name yet (we are accepting suggestions), we are calling it Motion FX beta (FX - full axis) ... As you can see, it has a nice feature of no angle limitation, that is still unexplored, but soon it will be fully functional... Hope you like it.
    http://www.youtube.com/watch?v=yGUcoUUYAx0
    It's not exactly a diy, considering that for building it you need to have some industrial equipment, but I think you may be interested in the project.
    This is the second sim we built, the first one was a Fullmotion (thanks again Thanos!).
    http://www.youtube.com/watch?v=44PU8cZSt_c
    Comments are welcome!
  2. kermit
    kermit Member
    Hi ,
    Very interesting project,
    Are you using Bonglioli MVF or VF gearboxes with a servo motor?
    What kind of plc and software are you using
    regards Henk
  3. Frakk
    Frakk Active Member
    328Coins
    Great job on the frame!
    I would be interested in how you control the position for the continuous rotation?
    What type of motors and electronics are you using?
  4. gsffair
    gsffair New Member
    - 150Coins
    Yes, it's a Bonfiglioli gearbox, I know the model isn't for that purpose, but it's working for now... If it breaks we will use a Type A!
    We are not using a PLC, we are using a msp430 Microcontroler and of course, X-sim (=
    Thanks for commenting.
  5. gsffair
    gsffair New Member
    - 150Coins
    Well, we don't control the position for the continuos rotation yet. I have some ideas on my mind, mixing two outputs from the force profiler, but we aren't in that stage yet...
    The motors are servo motors (1,5kw @ 2500 RPM !), with a gear reduction of about 90:1. The electronics are the servo drivers (they do all the hard work) and a msp430 microcontroller.
    Thx!
  6. Frakk
    Frakk Active Member
    328Coins
    Thanks!
    Are those AC or DC servo motors? 1.5kW must be really strong!
    Can you point us to those servo drivers?
    Also, they must be using encoders for positioning? Or a continuous rotation potentiometer?
    It will be interesting how you can solve the positioning for infinite rotation.
    Keep us posted about the challenges and your progress!
  7. gsffair
    gsffair New Member
    - 150Coins
    This are AC motors, 220V... I bought from here: http://hzmgdj.en.alibaba.com/
    It uses a encoder for positioning... It's very easy to use (=
  8. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Muito bacana o projeto, vcs estão de parabéns! :)
    However, I still think this kind of motion simulation better fits a flight sim, not racing... ;-)
    Cheers,
    MY
  9. gsffair
    gsffair New Member
    - 150Coins
    Valeu MasterYoda!
    I totally agree with you, this sim it's best suited for flight simulation... we just used first with car sim because we already had some experience... soon we will make a video using it for flight simulation... maybe using all the capabilities of the beast.
  10. lyspatriote
    lyspatriote Member
    photographer
    saint-Liguori Quebec Canada
    - 76Coins
    wwwwwwwwwwwwwwwwwwwwoW!
    amazing what you do there, i want to see more, look super!
  11. igorhr
    igorhr New Member
    computer technician
    Zagreb, Croatia
    405Coins
    First I must congratulate you on brilliance project.
    My frend and me was also tray to make a similar simulator, but
    we was give up , because were not find a solutions
    for a put wire inside tube and give power and signal to monitor, controller
    etc.
    so, I am nterested in how did you make solution for that?
    I see that you have some withe wire on main girder,or you use some
    strong battery under simulator seat?
    Also you said that you buy AC motors on link below
    Please, can you send me a direct link which motor is that?
    Regards
  12. AldoZ
    AldoZ Member
    Pc Shop
    366Coins
    Very great work there! And really BIG power!
  13. xtech007
    xtech007 Member
    29Coins
    Wow great project!
    Someone asked how to pass wires through the frame earlier, I believe no one answered that.
    Simple its called a SLIP RING this allows single or multiple wires signals to rotate 360 with out twisting the wires.
    Be aware the one you need has to be rated for that Purpose, like power rating and amps!
    A more sophisticated solution would be wire free! (Wi-fi)
    many little boards that accept serial and communicate via radio.
    but needs to be more elaborated.
    hope this helped!
  14. xtech007
    xtech007 Member
    29Coins
    gsffair
    Congrats on all the success this project has brought you and your Colleagues. I have read many Articles about your Project and its awesome to see how well the community has responded.
    Here we also strive to help and collaborate with each other to bring another Sim ALIVE!
  15. XCHDave
    XCHDave New Member
    this is exactly the project I am wanting to build! full motion is my goal!
    I am however far behind you. building the pvc joyrider atm to get an idea of how to do it.
    I will watch very closely at your project and see if I can catch up to you in development :)
  16. xtech007
    xtech007 Member
    29Coins
    XCHDave
    welcome to the Forum!
    We are both in the same path, I too like to build this sim!
    I have been trying to reach the original designer and no response.
    following the forum and the links I was able to gather data on the motors and drivers but no luck on frame.
    As for the X-sim software, yes it can gather all data desired to make this monster move!!!
    For the frame, I don't think PVC its an Option. 2 axis 360 motion and constant change of Center of gravity, might not be strong enough.
    Hallow metal tubing would be desirable.
    I have not found a detailed sketch of frame, IF SOMEONE HAS PLEASE SHARE!!!!!!! :hi:
    Hope to hear from you soon!
    Good luck!
  17. value1
    14,184Coins
  18. Deltaflyer47
    Deltaflyer47 New Member
    Yeah this is the kind of thing I am going after as well. Any information about the specifics of the original would be extremely useful.
    I have a general idea of the frame from the videos but still trying to figure out how he set up the motors to get that kind of motion and power.
    I have a pretty good general idea of how to put this together but specifics is where I need help.
