Question Power Surge Event might have killed 2 SCN6's - HELP
Discussion in 'Motor actuators and drivers' started by Jeremy Corbett, Apr 4, 2018.
  1. Jeremy Corbett
    Jeremy Corbett New Member
    Mechanical Engineer
    Brisbane, Australia
    167Coins
    3DOF, SCN6, Motion platform
    We have had a 3 axis car simulator running successfully for a couple of years and all of a sudden all motion stopped. It would appear that we had a power surge event that took out the Computer USB port, the 4-way USB hub, all 3 USB-RS485 adapters potentially 2 x SCN6's!
    I replaced the USB hub and wired in 3 new USB-RS485's was then able to communicate with each amplifier and get one axis running again, but I was getting errors on the other 2.
    I did a test matrix and found that all 3 external amplifiers work with the one SCN6 so no issues with them, but when I use the original working amplifier on the other 2 SCN6's I get an E8 error on one and E9 errors on the other.
    In the documentation errors E8 and E9 relate to encoder issues. The wiring hasn't changed since it was running successfully, and I have confirmed the amplifiers are working on a different SCN6, so that leaves "Defective encoder of Cylinder motor".
    Has anyone found a fix for E8 and E9 errors (without replacement)?
    Are replacement encoders available? Where?
    Hardware Details:
    1. DIY
    2. 3 DOF (roll, pitch & yaw)
    3. SCN6 actuators
    4. SCN interface
    Software Details:
    1. Simtools 2.2
    2. iRacing 64bit plugin
  2. Jeremy Corbett
    Mechanical Engineer
    Brisbane, Australia
    167Coins
    @yobuddy are you able to shed any light on this issue?
  3. yobuddy
    50,383Coins
    Unfortunately, I don't think I have ever seen this problem on the forums before.
    These are the guys to chat with thou.
    https://www.miraiintertech.com/home/scn6.php
    As they have been great to the community over the years.
    They may be able to provide you with the encoders.
    But more likely than not, you will need to send them in I'm afraid.
    (Hopefully someone else chimes in here with a fix.)
