Power supply burned
Discussion in 'Electronic and hardware generally' started by gigi, Apr 10, 2015.
  1. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Hallo to everyone!
    my problem:
    For my sim I use THESE MOTORS (mine with 50:1 ratio):http://www.ebay.it/itm/351066992384?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 ,
    2 BOARDS Pololu jrk12v12, and these 2 POWER SUPPLY: http://www.ebay.it/itm/ALIMENTATORE...sori_da_videosorveglianza&hash=item4d09f285df
    It's the third time that under certain conditions the game with highly stressed engines burning one of the power supplies: How can avoid this problem? The power supply do not have a fuse. Do yo suggest to put on wire + current from power supply to cards Pololu? what amperage fuse?
    Or there's another solutions ( for example better configuration of pololu board jrk12v12)?
    thanks for your help
    gigi
  2. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    Hi @gigi
    Do you have a wiring diagram on how you have it setup ?
  3. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    this is the wiring diagram
    150,704Coins
    +11,018 / 55 / -2
  5. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    highly stressed engines mean that in my games (rbr or assetto corsa) i like a setup of the sway and heave very responsive and fast. In some traks the motors move really fast and change direction very very fast
    150,704Coins
    +11,018 / 55 / -2
    Setting fast motor responses is pretty normal @gigi, I thought that you may have meant the motors were getting really really hot, which may indicate a design or electrical issue.
  7. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    The motors never been hot. Probabluy my setting ii two hard. but I'm not understend why the power supply burns. The pololu required 30A peak and the power supply are at 50A. The problem is that power supply don't have a fuse. Do you think that a can avoid to burn the power supply putting a fuse on the wire from this to board Jrk12v12. If yes how many Ah the fuse?
    150,704Coins
    +11,018 / 55 / -2
    A fuse is a good idea and cheaper than a PSU, but I suspect there is something fundamentally wrong if PSUs are burning out.
    The JRKs do have a max current limit setting.
    What watts are the PSUs rated at?
  9. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
  10. RacingMat
    21,022Coins
    Fuse is not really a solution: you cannot change fuse while driving each time to drive through a bumpy track part... ;)
    Probably better to wire a battery in paralell
  11. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    You suggest to out in parallelo the two power supply 12v wire?
  12. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Sorry bad english. You suggest to put in parallel the two power supply wire 12volt?
  13. bsft
    I run 40 amp PSU per motor with no problems, so not sure on that one.
    Put a car battery on to power both JRKS and see how it goes.
    Also, post up screen shots of your JRK tabs please.
  14. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Sorry for bad Quality
  15. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Another photo
  16. bsft
    Raise intergral limit from 2000 to 10000 , otherwise, apart from everything else looks ok.
    Try a car battery powering them both.
  17. Boomslangnz
    4,167Coins
    Are you using 1 power supply per motor? If you are then I would suggest trying different power supplies. Perhaps cheap Chinese ones aren't that good or such. A fuse properly wouldn't work that well as there isn't sustained constant load on it so Im doubtful it would blow due to overloading anyway as fuses are designed to handle overload for a small period
  18. gigi
    gigi Active Member
    913Coins
    2DOF, JRK, 4DOF
    Yes i use 1 power supply per motor
  19. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    It is always a good idea to fuse the motors..
  20. Martin van Hagen
    Martin van Hagen not trying brings you nothing! SimAxe Beta Tester Gold Contributor
    Instrument Engineer
    The Netherlands
    881Coins
    If it is not the same power supply that "goes to toast" then it could be poor design of the DC power supply, meaning no over-current and/or under/over voltage protection . Try to run both power supplies in parallel but make sure that both power supplies are on the same voltage level so the load is evenly spread. If not the highest power supply will take all the load and will follow the previous three supplies in the "Electronics Wallhalla". In the parallel configuration the load can be divided across both power supplies which might lengthen the life span. Concerning the idea of installing fuses it would not make much of a difference to the power supply and is mainly to protect the wiring/user(s) fed of it to the Motor controller, which should always be able to manage the maximum current from the supply or fuse if any installed.
