potentiometer noise
Discussion in 'Electronic and hardware generally' started by Smollett, Apr 4, 2020.
  1. Smollett
    Smollett New Member
    Russia
    86Coins
    Hello to all creators. I made my 2dof from Adruino Uno and Motor Shield, with two motors. I use SMC3 firmware . Everything works well, but I feel wild pain from cracking engines due to electrical noise in potentiometers. They make a terrible noise. In the SMS3 software, the yellow bar is like a cardiogram of the heart. It feels like you are sitting on an electric chair that has a short circuit and it pops on the whole house.
    I am sure that the problem is not only mine. Who knows the solution?
    150,542Coins
    +11,017 / 55 / -2
    Good cable management and clip on ferrite core magnets on all key leads should help.
    Personally I prefer Hall sensors to tradition cheap pots.
  3. BrazilianGuy
    BrazilianGuy eternal apprentice
    41Coins
    I am not sure about your setup, but placing a capacitor very close to the analog inputs of the arduino should also help to filter the high frequency noise. I am guessing your are using 10k pots, so it you would need something in the range of 10 to 100nF capacitance.
    You just cannot put too much, otherwise you risk slowing down your signal.
  4. Smollett
    Smollett New Member
    Russia
    86Coins
    In the previous firmware, which is simpler, I connected a third-party library 'ResponsiveAnalogRead'. This completely solved the problem. The output signals were smoothed and remained flat. I tried to use this in SMC 3, but my programming knowledge is not enough. I managed to get smoothed signals in Serial Monitor. But apparently due to this smoothing, there was no feedback, the yellow bar was at zero. Maybe there is someone here who can do this.
    I tried to install 0.1 mF capacitors on potentiometers. No result.
    I will try
  5. BrazilianGuy
    41Coins
    If this is some noise picked up on the wire or something similar, putting the cap on the potenciometers does not help much. It needs to be as close as possible to the pin from the ardruino.
  6. Smollett
    Smollett New Member
    Russia
    86Coins
    I will check it right now.) Thanks
  7. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    If your ADC is fast, another solution may be to use an average of 4 or 5 position feeback readings.
    I think this will attenuate the sound of the position feekback serve account for the position fix of your simulator
    Texte original en Français
    Si votre ADC est rapide , une autre solution peut être d'utiliser une moyenne sur 4 ou 5 lectures du feeback de position .
    Je pense que cela attenuera le bruit du feekback de position servent compte au correctif de position de votre simulateur
  8. Smollett
    Smollett New Member
    Russia
    86Coins
    Hello. can be more. how to do it?
    capacitor does not help. temporarily use the increase in the deadzone in SMC 3. But we must look for a solution.
  9. SeatTime
    28,320Coins
    Your not giving us much ... but, Shielded cable from the Ard to the Pots?
  10. Smollett
    Smollett New Member
    Russia
    86Coins
    no. conventional electric 2x1.5. thought to put a shielded.
  11. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    here's a snippet of code I had on the hard drive (Author ? )
    ReadAnalog <=> Of readings before averaging
    Code:
    void FeedbackPotWorker()
      currentanalogue1 = 0;
      currentanalogue2 = 0;
      currentanalogue3 = 0;
      currentanalogue4 = 0;
      currentanalogue5 = 0;
      currentanalogue6 = 0;
      for(int z=0;z<ReadAnalog;z++)
          currentanalogue1 += analogRead(FeedbackPin1);
          currentanalogue2 += analogRead(FeedbackPin2);
          currentanalogue3 += analogRead(FeedbackPin3);
          currentanalogue4 += analogRead(FeedbackPin4);
          currentanalogue5 += analogRead(FeedbackPin5);
          currentanalogue6 += analogRead(FeedbackPin6);
      currentanalogue1 /= ReadAnalog;
      currentanalogue2 /= ReadAnalog;
      currentanalogue3 /= ReadAnalog;
      currentanalogue4 /= ReadAnalog;
      currentanalogue5 /= ReadAnalog;
      currentanalogue6 /= ReadAnalog;
  12. Smollett
    Smollett New Member
    Russia
    86Coins
    thanks. I understood the idea.
