Positioning pot rotation question
Discussion in 'SimTools compatible interfaces' started by kevinket, Sep 20, 2011.
  1. kevinket
    kevinket New Member
    Springfield, Oregon
    I've certain I don't have enough movement in my positioning pots.
    The video shows 62% at extreme left and 78% at extreme right:
    http://www.youtube.com/watch?v=zBtQEYK37IY
    Then, when the calibration is complete, the test axis result value changes to 100%.
    Will this prevent the Math Setup for being able to calculate a center position, and therefore render the Center option on the Calibrate Setup from working?
    Thanks, Kevin
  2. bigtalltim
    bigtalltim New Member
    Belfast
    361Coins
    Hi Kevin
    You need to either change your pots to one with a smaller sweep, or better still, use some kind of gearing to maximise the useage of the pot.
    Currently, your build is only using 16% of the capacity of the pot.
    The maths setup will compensate for this when you callibrate, and apply 0% position to your 62% and 100% position to your 78% (and it will show mid position when the pot returns what would have been your 70%)... but your position feedback will be awful! not even close to the level of control needed for a sim running at any kind of speed.
    You should always aim to get maximum movement out of your pot or slider - try a 45 degree pot, or gearing ;)
    Tim
  3. kevinket
    kevinket New Member
    Springfield, Oregon
    I'll get some gears and re-work it.
    Thanks for the guidance.
