Question plugin details for AMC simtools 2.3
Discussion in 'SimTools Pro & Entertainment Version' started by billo2404, Oct 5, 2018.
  1. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    Hi guys, finally now even with the Thanos you can use simtools so I bought the pro license.
    Now the only combination that seems to work is the 2.4 frmware on the AMC after buying the hexpod 1.7 plugin and the simtools version 2.25.
    I would like to know what type of plug-in uses the 2.3 version of simtools, if it had been and with which firmware loaded on the AMC.
    Thank you
    Salve ragazzi, finalmente ora anche con la Thanos è possibile utilizzare simtools quindi ho acquistato la licenza pro.
    Ora l' unica combinazione che sembra funzionare è il frimware 2.4 sulla AMC dopo aver acquistato il plugin 1.7 di hexpod e la versione 2.25 di simtools.
    Vorrei sapere che tipo di plugin usa la versione 2.3 di simtools, se fosse stato e con quale firmware caricato sulla AMC.
    Grazie
  2. yobuddy
    50,374Coins
    @Thanos,
    When you have time buddy...
  3. Thanos
    Electronics Engineer
    United States
    2,848Coins
    Yes, seen all of these. Almost done with other tasks, to focus and test the new version and untangle this mess of conflicting reports.
