Question Planning a G helmet system, Examples?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Trigen, Jan 12, 2020.
  1. Trigen
    Trigen Active Member
    2,892Coins
    Hi there chaps
    Im planning on making a G helmet system. I have a rough idea but id love to see some finished projects.
    Anyone got some finished or WIP ?
    Thanks!
    Christian
  2. RacingMat
    21,088Coins
    Hi!
    what is G helmet?
    have you seen some commercial products?
  3. Trigen
    2,892Coins
    What ive seen in a F1 sim is a motor mounted on the back of the seat with a long lever which connects to a helmet and pushing it from side to side as you drive in the cornerns and producing fake g forces. Fairly sure Seattime is using that setup. Ive also seen cables connecting from the sides and using pulleys but that seems to take a lot of space.
  4. BlazinH
    16,698Coins
    Two major issues with that system is its missing surge and even worse its appears to use position instead of torque to drive the actuator.
  5. Trigen
    2,892Coins
    I'm not planning on using that design so that's fine. Was just to show. I'll be doing only sway first since I have what I need but I'll set it up so I can just mount the surge motor to the frame that holds it and I got both.
  6. Trigen
    2,892Coins
    I'm also considering just attaching some elastic chord to my belt tensioner for acceleration surge. It's not a roller design so it's just hocking it up
    154,400Coins
    +11,181 / 57 / -2
  8. lap345
    lap345 New Member
    Australia
    285Coins
    Hi there, just came across your original post and thought I'd point you to my very basic build from a few years ago.
    https://www.xsimulator.net/community/threads/low-cost-head-motion.9233/
    For how simple and small it is, it was surprisingly immersive. I initially saw it as a learning exercise and didn't expect it to work well but it did. While the primary vehicle accelerations were the main driver, a nice surprise was the detail offered by bumps, rumble strips, gear changes, etc. You could feel it all through the helmet and really made you feel like you were connected to the vehicle.
    Interested to hear if you have made any developments yourself.
