pCARS 2 game update 3.0
Discussion in 'SimTools Plugins' started by Hobbs77, Nov 28, 2017.
  1. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    pCARS 2 update 3.0 pc just came out and I have no in game motion. Everythings set in game properly or as it was before update. Game manager turns blue when starting game but no motion and also unable to capture motion. Thanks.
  2. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    uh oh... I have not updated yet as I am at work... Hope it is not a patch induced issue...
  3. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    I got the feeling it is!:(
  4. Brett Horton
    Tampa FL
    118Coins
    Motion works just fine with the new patch. It is glaringly obvious that it is the new patch running as well. Fixed the game!
  5. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Well, what the...... works with all my other games and worked with this until new game patch this morning. Maybe I'll try restarting my pc.
  6. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    UPDATE.....Restarting the pc didn't help which got me to thinking, if it's working for others .......so I change the in game shared memory setting to pc1 and it's working now. I had it set on pc2 which worked before todays game patch. Maybe someone else can also verify this. Thanks
  7. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Can anyone else verify that after pCARS2 3.0 game update the shared memory in game pc2 setting doesn't work anymore and needs to be set on pc1 or am I the only one? Thanks in advance.
  8. Fredymilou
    Fredymilou New Member Gold Contributor
    Electronique , mécanique
    134Coins
    Pcars2 have just been updated with patch 1.3.0.0.
    This also includes an update of the shared memory that has been upgraded to version 9.
    Does anyone have the new version of "SharedMemory.h"?
  9. Andy Booth
    Andy Booth Active Member
    Malaysia
    430Coins
    Always had it set to pc1 so I guess thats the way to go guys.
  10. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    It's one thing after another lately:).........Now I'm having a problem with sway not working, left and right movements of my rig with pcars 2 only. All other games are fine atm. I'm not even sure it worked after I switched it over to pcars 1 in the shared memory settings after the pc 3.0 update earlier in the week as I haven't used it much this week.
    Am I the only one having this problem?:cheers
  11. Andy Booth
    Malaysia
    430Coins
    I never have sway set high enough to register to be honest because its the one movement that makes me feel ill.
    Let me give it a try with more sway and come back to you.
    Andy
  12. Andy Booth
    Malaysia
    430Coins
    Just tried with sway turned up and all seems to work fine.
    Andy
  13. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Thanks Andy....I usually set it on the low movement side also. Just enough to enhance the game without it swaying me all over the place and that's probably why it took me awhile to notice it wasn't working with pc2.
    I've tried recapturing the motion again and even shut down everything but nothing so far. It works fine with other games so it must be something with this game and only with me!?
    I'll work on it later today if I get a chance and I'm open to suggestions if anybody has any....thanks!
  14. Andy Booth
    Malaysia
    430Coins
    To be honest @Hobbs77, I'm beginning to doubt myself now.
    I'm going to try again tonight and crank the Sway to the max and make sure what I'm saying to you is correct.
    I'll let you know
    Andy
  15. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    OK...I finally fixed it!:) Not sure what caused the issue to begin with but somehow the pc2 game plugin 2033 got corrupted and the sway stopped working with pc2 game only. Sometime between the game patch release and this past Saturday, Dec 2nd.
    I unpatched and re-patched the game several times along with all the other motion setup things but nothing worked. I finally reinstalled the plugin, patched it and I'm happy to say, everything is back to normal. :thumbs
    So now I'll know when things like this start going wonky, I'll start with the game plugin first.:cheers Now if I can only remember something longer than 5min.:grin
    • Winner Winner x 3
  16. yobuddy
    50,714Coins
    I know how you feel.
    I had to look something up the other day, and hunted all over the net.
    Only to find the answer to exactly what I was looking for!
    It was so perfect in fact, I wanted to send a thank you note to the poster.
    Only to realize, it was me from years ago. :p
    You have to love it, when your past self, is looking out for your future self. :thumbs
    (Even if it's by accident) :grin
    • Funny Funny x 2
