ordered a new toy (CNC Plasma)
Discussion in '3D Printing' started by crammy, Dec 16, 2016.
  1. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Hi All
    Probably in the wrong section so please move if it is.
    I've ordered a cnc plasma table(not personally but for my company) capable of cutting 40mm mild steel plate so it's not to bad. It should arrive and be setup by the end of January which is perfect timing for me as i'm going to start my 2nd project. I can cut all the Aluminium floor plates and put holes in accurately so all should be perfect and pretty straight forward.
    I wouldn't mind building a decent set of pedals, so have any of you, got or seen any plans for some.
    Also I'm looking out for sim bits i can make so if any of you UK based people have anything you need ill try and make them for you at cost of material plus postage if i can. I'm more than happy to help the community
    cheers
    Jay
    • Friendly Friendly x 3
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    @crammy do you play Iracing? Beano has a write up, there in the forums under hardware or DIY controllers can't remember which. He uses Tilton or something similar. Either way he shows his pedal project. Also Jason Jodarski built a few sets and can also help.
  3. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Thanks @bruce stephen.
    I'll join the forum and have a look.
    I've not got I racing sorted yet but will definatly when I get my new wheel.
  4. ferslash
    ferslash Active Member
    4,798Coins
    envy is a capital sin right? :D:D:D:D so i will say that i dont envy you :D:D:D:D
  5. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    lol @ferslash . happy to try and make some bits for you if your in the uk, however don't count your chickens as me and tech don't get om. my 4 week old rift has no screen on anything. just got the orange light
    150,728Coins
    +11,018 / 55 / -2
    Have you contacted Oculus Support and what are your system specs, plus what USB ports are you using?
  7. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    panic over. it was my mate somehow getting into my home network .he literally took over all my shit from an s7 edge. he just just did it to get me off the seat as the women (our other halves) were boring him
  8. Historiker
    Michigan USA
    9,208Coins
    Moved for you. We do not really have a cnc section, this is as close as we get but perhaps we should edit the section title?
  9. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
