optimum angle to set 100mm actuators
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Brightonuk, Nov 28, 2009.
  1. Brightonuk
    Brightonuk Member
    Business Owner
    Plantation, FL
    492Coins
    What is the optimum angle to set 100mm actuators for a FREX type set up I see some that look like a 30 degree rake and others at nearly vertical.
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    The angle is not quite as critical with 100mm because they do not move your body weight as far from the pivot center meaning that they wont be lifting as much load.
