One Computer to run everything?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by netwizrm, Sep 19, 2009.
  1. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
    Hello
    I am new member and very new at this, I need some advice on weather one needs two computers to to run a 2DOF Mr. Burns type Sim?
    If I have a fast enough computer i.e. Intel 2 Core Duo 3.0Mhz, 4GB. Can I run the game software and x-sim apps, i.e. the profiler, the force-sender, Plugins off the same system?
    I this economy I am hoping this is do-able. please advise.
    Robert
  2. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    It depends: if you will use it for LFS, Dirt, Race07, GTR thats ok but for new ones like Grid, Dirt 2, Shift, Race On (if we will get plugins for them three last ones) you can get noticeable decrease in time when you play.
    Extra hardware works separately from main one and even if it is slower one its run only x-sim software leaving other one to handle a game. Cheap laptop will deal with this.
    I have same set up as you but CPU is overcolcked to 4ghz and GPU is Ati Radeon 3870 X2. Everything up to date works perfect - even grid with some details turned off (i do not like the crowd in the game and thats hlep with game speed).
    Oh... and one more thing - it is nice to see how x-sim works next to you when you play. You can also make some instant changes.
  3. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    811Coins
    I have been a xsimmer for 3 days now...
    Converted from frex SCM that i used 2 years, i have to say this rocks, but i too run it on one computer, but mine is not as fast as you guys, intel core 2 duo 6600 2,4 with a Gforce 8800 320 mb with 2 gb of ram.
    Most games work ok, but when i go online on the nordschleife for instance, the motion can't keep up.
    I have a spare netbook from asus an eeePC running XP (lite) and a intel 900mhz, it does however have 2 gb of ram.
    Wil this litte notebook work? and does it work with WIFI? or do i have to hook a lan cable to it?
    Thanks in advance.
    Rob
  4. ebinary
    ebinary New Member
    2Coins
    I run fine on a quad core
  5. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
  6. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
    Splendiddd, wireless networking is has always been considered a neat and clean setup, but with every advanced technology comes complexties,
    In the market we now have 802.11n technology which is the third-generation of Wi-Fi standards for wireless home networkin a much faster wireless connections over longer distances.but not cost efficent.
    802.11g supports 54Mbps divide that by two or actual speed.
    Also when dealing with wireless Wi-Fi connections you have to consider WPA and WEP security features, it works well but could get messy.
    I am sure the networking portion of your X-Sim setup would work the same wire on not but you need to check forum for more answers.
    I hope I didn't talk too much.
    Robert
  7. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
    And you experience no game slowness? And how many Gigs of RAM, What GPU Specs?
    Robert
  8. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    In the context of X-Sim, speed of your wireless network is not the concern. Latency is the concern, and even 802.11N introduces far too much latency. Search wireless latency on these forums. Somewhere there is a thread where SirNoName and I discussed this. A graph was made to demonstrate why you should not use wireless networking with X-Sim due to latency.
    :cheers:
  9. splendiddd
    CCTV security
    Netherlands
    811Coins
    Thanks guys for clearing things up!
    Wireless wil not be a option i guess, is not a big problem, there will stick 2 usb cables out so a network cable is not an issue.
    Anyway i installed xsim on the asus, but it doesn't even fit on the screen :eek: , so i think i stick to my one computer setup for now ;)
    Regards,
    Rob
