Question Oculus Rift DV1 Sensor positioning help
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Jean Paul Andrade, Dec 9, 2020.
  1. Jean Paul Andrade
    Jean Paul Andrade Member
    272Coins
    hi! I've been using my Sim with oculus Rift S and even if sometimes I get dizzy by the motion, I get use to it. I recently bought the Oculus Rift CV1 and I I have seen other set ups with only one sensor mounted in the structure right in front of the steering wheel, what should I do with the other sensor? and wouldn't be this a problem when the oculus software tries to set up the system and track the touch controllers? I tried to find documentation about all these isues in the forum but still nothing clear, I really apretiate your feedback.
    150,614Coins
    +11,017 / 55 / -2
    Long time since I used the CV1, but you should be able to disconnect or just cover a camera once the setup is done and it should track fine with one camera.
    Keep in mind very fast motion or transducers can mess with the rig mounted camera's tracking.
