Oculus meta 2 absence of movement
Discussion in 'Forum and Website' started by nanofico, Oct 24, 2022.
  1. nanofico
    nanofico New Member
    - 24Coins
    Good morning everyone. They gave my son an oculus meta 2 viewer. Connecting it to my 2dof it does not perform any movement, what should I do to make it work?
  2. MoreSine
    MoreSine Member
    Hesse, Germany
    157Coins
    can you give a bit more detail on how you are using it?
    The Quest 2 is a standalone headset, so if you want to use it with PC Games you have to either connect it via a cable or use AirLink / Virtual Desktop.
  3. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    I've got a different headset but I guess that Oculus is just a viewer as mine.
    Your 2DOF should keep working as it does when the viewer is not connected and you are using your monitor
