Question Non linear motion in Simtools??
Discussion in 'SimTools Pro & Entertainment Version' started by sberns, Mar 4, 2020.
  1. sberns
    sberns Member Gold Contributor
    432Coins
    3DOF, SCN5, Arduino
    Is it possible to emulate non-linear motion using simtools (like a gamma modifier)?
    Due to the design of my GSeat, movement of the panels for the first 25% of total travel is reduced relative to the middle 50% of travel. So I would like a way to “amplify” the motion for the first 25% of travel only and then make it more linear for the remainder.
    Is this possible? Thanks.
  2. KydDynoMyte
    RTP, NC
    92Coins
    Are you already using the Rotational Output Type?
    The only thing similar to a gamma modifier I can think might work a little is using anti-rollover while artificially doubling the game data in tuning center so you are only using half of the anti-rollover feature over the whole physical travel.
  3. sberns
    432Coins
    3DOF, SCN5, Arduino
    I’m using linear not rotational motion as motion is via a linear actuator.
    can you explain how the anti-rollover effect works? I’m not familiar with that as I only use it for sim racing. :) thanks.
  4. KydDynoMyte
    RTP, NC
    92Coins
    Sounds like you have that linear actuator rotating a panel. I'd try rotational output type first.
    I'd swear I read somewhere it slows down before reaching the point it reverses so you don't get jerked the other direction. If you double the game data in tuning center, the max game data should stop right before it reverses direction.
    Or I might be completely wrong. Good luck.
  5. yobuddy
    47,902Coins
    Hi @sberns,
    If you using an Arduino for the controller, I would look to do this there.
    If not, you could try setting the output type to rotational, as it will make it move faster from zero, and slower when it gets to the ends of the actuator.
    take care,
  6. sberns
    432Coins
    3DOF, SCN5, Arduino
    My GSeat is connected to @Thanos ’s controller. I tried the rotational option but unfortunately I didn’t notice any change. Wish there was a option similar to gamma correction.
  7. Thanos
    Electronics Engineer
    United States
    2,692Coins
    You could convert the rotation motion to linear using something like brake wire that in used on brakes on motorcycles perhaps...
