Question No motion in game only
Discussion in 'New users start here - FAQ' started by jaynnc, Oct 27, 2020.
  1. jaynnc
    jaynnc New Member
    - 11Coins
    3DOF, Motion platform
    Eveything was working perfectly and then I accidentally uninstalled simtools, reinstalled, set everything back up...the actuators work when I test via thanos and simtools, game is patched, ip address it correct.... when I start the game, the actuators rise up but no movement( I have a sfx 100)....I pulled the usb out and put back in and now it work with SRS but not simtools(only testing works)...Please help
    150,722Coins
    +11,018 / 55 / -2
    Can you please check if there is a port conflict if you are using a mix of software.
  3. Thanos
    Electronics Engineer
    United States
    2,848Coins
    Hmm, maybe SRS is running in background and blocking the simtools? Did you try closing the SRS from running in the background (in the tray) ?
