new user -cant get dcs plugin into game manager
Discussion in 'SimTools DIY Version' started by Adrianstealth, Sep 3, 2016.
  1. Adrianstealth
    Adrianstealth Active Member
    director
    england
    334Coins
    SCN6, 4DOF
    Ive tried drag and drop but no luck
    its stuck on live for speed ( in built one )
    I've left plug in zipped and ran game manager in admin mode
    when I try to drag and drop it will not except the zip plug-in file
    am I missing something out ? can someone please put a simple step by step procedure
    I've spent an hour reading the instructions but they are zero help and lots of info i dont need
  2. Adrianstealth
    director
    england
    334Coins
    SCN6, 4DOF
    the game manager will not accept the plugin when i try to drag and drop
  3. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hello
    witch one version Dcs used? need used |DCS ( not dcs beta)
    150,602Coins
    +11,017 / 55 / -2
    I am just checking the basics, can you please confirm Game Manager and Game Engine are closed and that you are using the SimTools PluginUpdater to drag the plugin on to, found in the SimTools entry of the Windows menu, or directly in here C:\Program Files (x86)\SimTools\SimTools_PluginUpdater.exe
  5. Adrianstealth
    director
    england
    334Coins
    SCN6, 4DOF
    hiya
    thanks for reply, i tried the one in the plugins section + one that was user made in forum, both same problem
  6. Adrianstealth
    director
    england
    334Coins
    SCN6, 4DOF
    i will try this, so I am not to open sim tools at all, and use this updater thing in this file ...ok i will,give his a try, big thanks
  7. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,096Coins
    DC motor, AC motor, 4DOF
    @Adrianstealth How did you go?
    I am having the same problem. When you drag any plugin file over the running SimTools_PluginUpdater.exe program box on my game PC, the pointer changes to the stop pointer and not the + pointer to indicate it can drop in?
    All programs were run as administrator.
    Partial installations were run as per each PC.
    Ensured SimTools_GameManager was not running.
    Firewall was checked to ensure that the .exe's were listed.
    On failure to drop an uninstall was done and a complete power down to flush memory.
    Installation was done for both the default directory and to C:\simtools => to allow full access to this directory by Windows 7 - Thanks billy G!)
    On repeated failures a manual registry flush of simtools entries was done after uninstallation prior to full power down.
    Live for Speed shows as the default game in partial installation whereas a full installation gives the option to not install it.
    In my particular instance this is what transpired to my predicament...
    I have two PC's running win7 and the game PC is patched to the latest release dcs world. The second PC is controlling the G-Seat and work very well with SMC3 (Many thanks again Rufus!!!). Over the weekend I did a full install on both the game and controller PC and was able to drag and drop the DCS plugins (Both standard and Rifts - but I thinks Rifts is standard now too?). When I got to do a full game test between the two PC's I could not see a UDP connection show up and of course there was no game data transfer. After verifying port numbers and export.lua I resolved that I did not do the partial installation necessary for each PC. I did a self contained install on both PC's?) I uninstalled on both PC's and did the required partial install on both PC's to C:\simtools.
    and appeared to install okay. I then proceeded to install the plugins as part of the setup but found the game PC would not accept the dragged plugin no matter what steps I took.
    The controller PC works and I can drag any plugin all day...
    150,602Coins
    +11,017 / 55 / -2
    Do not run the Plugin Updater as admin.
  9. BrassEm
    NE of YMML
    1,096Coins
    Excellent noorbeast. That was it. Learn something new everyday. I've almost always run exe's as admin to give full access when I remember. I am curious as to why it did not work with admin rights. (Path ways I suspect?).
    Thanks again. Another hurdle passed.
  10. Adrianstealth
    director
    england
    334Coins
    SCN6, 4DOF
    big thanks noorbeast
    i found the thing hiding in the folder, my memory is coming back too lol
    I also was un-zipping the plug-ins which is wrong, shames things are not a bit more user friendly
    as some people never bother with forums
  11. Adrianstealth
    director
    england
    334Coins
    SCN6, 4DOF
    yes its misleading
    find the thing that noorbeast mentioned its a 3rd item hiding that you need to drag and drop the UNZIPPED plug-in file too,
    that should work
    again ....do not un-zip the plug in keep it as it is and drag and drop
  12. yobuddy
    50,295Coins
    We also have a manual if you don't want to read the forums. ;)
    With SimTools 2.0 thou, it does not matter if you unzip the files or not.
    Making it easier and more user friendly.
    Yes, using admin writes blocks all drag and drop functions as a security measure in windows. :roll
    But there is no real reason to run the updater as admin anyway, so it all works out! :thumbs
