New member -> propably AASD issue.
Discussion in 'Direct Drive Wheels' started by MIkolaj, Aug 19, 2021.
  1. MIkolaj
    MIkolaj New Member
    79Coins
    Hi there!
    I make a DDWHL with [STM32F4Disco \ AASD \ MMOS \130st_m10015] - it's a project from Peacemaker topic.
    It was working good 2 months with MMOS but one day when I chenge the place propably I change some parameters on AASD and now I havnt smooth wheel. Its working like "step by step" like overload. In next post I'll put a video.
    Maybe you know what's wrong, because I'm slowly giving myself up, I tested it on two STM32s and they both work the same. Try to back setting on AASD to defual by PN04 but with no effect.
    ps. I wrote it in the Peacmeker topic, but it seems to me that many people don't look there anymore, so I started my own topic.
  2. MIkolaj
    MIkolaj New Member
    79Coins
    And this is the movie with issue..
  3. Gadget999
    12,319Coins
    what board do you use to control the servo ?
    does it use a DAC ?
  4. MIkolaj
    MIkolaj New Member
    79Coins
    Hi!
    I have exactly the same configuration as in the Peacmaker topic. It is pure SMT32 + AASD driver + servo. I think there is no DAC, but the most surprising thing is that it worked like this for 2 months and nothing happened and now it unfortunately works like in a movie ..
  5. Gadget999
    12,319Coins
    I suggest you fit a DAC and see if it improves
  6. MIkolaj
    MIkolaj New Member
    79Coins
    OK, Thank You!
    I'll check it!
  7. Steve B
    Steve B Member
    248Coins
    Check the 3 phases to the motor are on the correct terminals on the aasd.
    U V and W need to be in the correct order, running the motor with the wrong phase order can de-magnetise it destroying the motor.
  8. MIkolaj
    MIkolaj New Member
    79Coins
    Thanks Steve for your reply, I checked and they are connected properly.
    Now I think to replace AASD with something else like VESC + STM32 .. I am currently looking for the best solution.
  9. Steve B
    Steve B Member
    248Coins
    It looks like it's not able to find/hold it's position. Check you have the correct settings in MMOS as per peacemakers thread. There are two ways to control it, pulse and direction or 0-50-100.
    I've only used pulse and direction but others have reported both work.
    Confirm all settings related to the encoder (in MMOS) are as per peacemakers thread.
    Is it possible the encoder wiring is damaged, mine is a little fragile in the pre wired cable at the d-sub end.
  10. MIkolaj
    MIkolaj New Member
    79Coins
    Hi Steve!
    I checked the connections \ settings \ and soldered the DB25 several times to be sure (like in Peacmaker topic). Now I know it's not really that. I also checked the cables from the servo side if nothing is broken and it's ok. Today I will check as you suggest on the d-sub side.
  11. MIkolaj
    MIkolaj New Member
    79Coins
    D-sub side is ok, when I run the motor (without db25) just by FN002 its start and then stop like with break then it show AL-006, so its issue with AASD or Servomotor.
