Needing info on Digital Contactless Pots I've purchased
Discussion in 'Forum and Website' started by cthiggin, Apr 1, 2014.
  1. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hi Folks,
    I'm getting very close to needing my "electronics" for my AC Platform build - have two threads running now.
    I've already purchased from Digi-Key 3ea of the Contactless Digital Pots 180.
    Question 1: I know you can check a linear/wiper pot and set the indexing point - so you have a basis or starting point when mounting them. IS there a way of checking my contactless pots - I know there's a "little" bump or ridge at the top which would be center or 90degrees, but it won't tell me IF I'm 180 degrees out???
    Does one just wait until they are physically hooked up and then set?
    Question 2: I will have one pot that I have to electrically change when the right side becomes 0, and the left side would be 180 degrees - just the way my motors will be positioned with crank arms..... from what I understand, you have to do this with a "firmware" write..........and I don't know one thing about that.
    Your thoughts would be appreciated.
    Have a blessed one.
    Tom
  2. BlazinH
    16,651Coins
    Answer to question 1: You need to use a voltmeter to find the position of these pots. 2.5 volts is center. Once you find it you can put a mark on it with a sharpie or something yourself to find it again. Just connect it to a 5v source and test it!
    Answer to question 2: As I stated previously, don't sweat the "firmware" part right now. It will be an easy fix once you can give us the information required to reverse the right motor.
  3. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hi BlazinH,
    Thank you for settling this for me.
    I must ask (since I've never been the electronics route before) WILL this be 5v AC or DC - ALL my low voltage stuff when I build my pc's is DC.
    Thanks, Tom
  4. SimonUK
    SimonUK Member
    Electronic Engineer
    England
    705Coins
    Your pots need 5V DC.
  5. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    SimonUK,
    Thank you for the info.
    Don't know "what" I was thinking - not much evidently??? as the SimAxe Boards etc. get power from the USB -
    I "should" have known without asking - but reaffirming helps.
    Again, Thank You.
    Tom
  6. RaceRay
    23,875Coins
    @cthiggin Please post similar questions in the FAQ section. This thread is only for website related questions.
  7. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hi Rene',
    Sorry friend. Sure didn't mean to do that, AND, it won't happen again!
    Do have a "simple me" question....when I go to Community, then click on new posts, of course I see new ones....I have had a couple of Topics started on my build, etc., and posted in the right section,
    however, I have not seen them posted in "new posts"...why is this?
    Thanks and have a blessed day.
    Tom
  8. RaceRay
    23,875Coins
    When you ve posted them by yourself they do not occur for your account in the "new posts" section because you already know them as the author. All other guys will see them;-)
  9. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hi Rene,
    GEEEZE, I keep learning your methodology - I was "thinking" that no one was seeing them - thus the "Digital Pot" thread in the wrong section....
    And based on this, "me" would think that the replies you would get from your topic would be when "watch" has being clicked?
    Thanks so much for the info....now "me" know.
    Tom
  10. RaceRay
    23,875Coins
    Your welcome mate:)
  11. value1
    14,949Coins
    @cthiggin: when you have written a post, click on "Recent Posts" rather than "New posts" to see what you have written.
    T.
  12. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    value1 & rene,
    Thanks so much - still learning - and you folks know by now that I'm one of these old fellows that comply......just want to be "forum correct".
    Have a blessed day,
    Tom
  13. eaorobbie
    20,467Coins
    Ok back to topic,
    With the Simaxe, you will see the pots position on the Lcd and can rotate them for installation easily.
    Changing the code in the SimAxe is easy too, when at that stage I would ask the Author @yobuddy to explain, Im sure he will do.
  14. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    eaorobbie,
    Sorry for the off topic - wanted to clear things up after my boo-boo.
    Thank you for your explanation on the pots with lcd and the code change to reverse the pot.
    Many blessings,
    Tom
  15. eaorobbie
    20,467Coins
    No worries mate thought I would answer the question for ya.
  16. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Thanks eaorobbie,
    Your continued help is so appreciated!!!
    Have a blessed day,
    Tom
