Need help with wiring for Dual Clutch with bite point adjustement
Discussion in 'DIY peripherals' started by HoiHman, Mar 5, 2018.
  1. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    Hi i'm currently building a new rim and want to add a dual clutch with bite point adjustment.
    I found this picture of a board from Martin Asher, but need some help to "reverse engineer" this, since this should be that hard to make yourself.
    This gif shows how the final solution should work.
    https://s19.postimg.org/s9fwq1jgj/standing_start_procedure.gif
    Could some one please draw me a electric drawing how to wire this dual clutch.
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    what would be the purpose of two clutches? I watched the illustration but I dont understand the purpose.
  3. HoiHman
    Mechanic
    The Netherlands
    331Coins
    It's basically for lighting starts.
    A dual clutch system ( like in F1) enables you to make the perfect start over and over again. It's explained in the video below
