Need help with load cell brake
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by butternutz, Apr 12, 2022.
  1. butternutz
    butternutz New Member
    16Coins
    I'm trying to build a racing sim. I have two pots--one for steering and one for accelerator. I'm using a load cell for the brake. The load cell is using a HX711 and all this is wired to an Arduino Leonardo. Here is the program for the Arduino.
    Code:
    // https://github.com/MHeironimus/ArduinoJoystickLibrary/tree/version-2.0
    #include <Joystick.h>
    #include <Q2HX711.h>
    Q2HX711 hx711(A4, A5);
    Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID, JOYSTICK_TYPE_JOYSTICK, 1, 0,
                       false, false, false,  // axis x, y, z
                       false, false, false,  // rotate rx, ry, rx,
                       false, false,         // rudder, throttle,
                       true, true, true);    // accel, brake, steering);
    const int button_pin = 2;
    int button_value = 0;
    int steeringPin = A1;
    int gasPin = A0;
    int steeringValue = 0;
    int gasValue = 0;
    int brakeValue = 0;
    void setup() {
      Serial.begin(9600);
      Joystick.begin();
      pinMode(button_pin, INPUT_PULLUP);
    void loop() {
      steeringValue = analogRead(steeringPin);
      gasValue = analogRead(gasPin) * -1 + 850;
      brakeValue = hx711.read() / 1000;
      Serial.write("Brake is ");
      Serial.println(brakeValue);
    //  Serial.write("Gas is ");
    //  Serial.println(gasValue);
    //  Serial.write("Steering is ");
    //  Serial.println(steeringValue);
      //Controller assignments
      Joystick.setBrake(brakeValue);
      Joystick.setSteering(steeringValue);
      Joystick.setAccelerator(gasValue);
      button_value = !digitalRead(button_pin);
      Joystick.setButton(0, button_value);
      delay(200);
    Now here is what I don't understand. The gas and steering are fine, but I have an issue with the brake. The brakeValue will print to the serial monitor but it will not show up in Windows game controller settings. To be more clear I go to "Devices and printers" and then choose the Arduino. I open 'game controller settings' and try to calibrate it. When I get to the brake callibration part, if I check 'show raw data' there is none. But I can have the Arduino software open at the same time so I can view the monitor or plotter and it will show that brakeValue is changing.
    I'm pretty lost. Any help at all getting this working will be appreciated.
  2. Erik Middeldorp
    Erik Middeldorp Member
    sheet metal worker
    Auckland, New Zealand
    639Coins
  3. butternutz
    16Coins
    Thanks. I went to look at the return type and stumbled across the problem. There's a setBrakeRange that defaults to a certain min and max. My readings were out of range. So I used that function and set the range to what I needed and BINGO!
