Showroom My rotary 6-DOF racing simulator project
Discussion in 'DIY Motion Simulator Projects' started by 毛大大, May 3, 2026.
Tags:
  1. 毛大大
    毛大大 New Member
    64Coins
    – here’s the current progress, and I’ll keep updating it go
    6DOF base frame, 5050 square tube, 4mm thickness
    Reducer mounting bracket; I sprayed two coats of paint: one anti-rust coat and one finish coat.
    Frame assembly completed.
  2. accelero
    accelero Member
    france
    293Coins
    2DOF, AC motor, Arduino
    strong design......looking forward watching the rig in motion
  3. Jon Amico
    Jon Amico Member Gold Contributor
    540Coins
    What is it? A fill Size Alien Spacecraft 6 DOF? Looking sick... And Mean!
    Love it!
  4. 毛大大
    毛大大 New Member
    64Coins
    I've been quite busy with work lately, and I'm waiting for the processed upper platform to arrive.
  5. Garrett
    Garrett Member
    327Coins
    For best performance, you want the center of gravity over the top of the 6 motors.
    In the illustration above, it appears to have the cockpit a few feet from the center of the six motors.
    Unless you have insanely powerful motors, not sure that offset cockpit concept will work without extensive gas strut help.
  6. 毛大大
    毛大大 New Member
    64Coins
    Servo motor homing failed
    . Here are my servo parameters. I'm stuck, anyone can help?
    pn002 = 002 (Step/Dir control mode)
    pn003 = 001 (Servo enable)
    pn098 = 80 (Electronic gear numerator)
    pn109 = 002 (Position command deceleration mode)
    pn110 = 050 (Position command filter time constant)
    pn111 = 050 (S-curve filter Ta)
    pn112 = 050 (S-curve filter Ts)
    Homing:
    pn024 = 20
    pn033 = 3 (Power-on homing enabled)
    pn034 = 0/1 (Homing direction: 0=CW, 1=CCW)
    pn036 = 11 (Coarse position ×1000 pulses)
    pn037 = 5000 (Fine position)
    pn038 = 100 (Initial speed)
    pn039 = 100 (Return speed)
    https://www.youtube.com/shorts/NWRFQZ_7khw?feature=share
  7. Misanthrop
    Misanthrop Active Member
    1,006Coins
    Be sure you have the correct Driver Settings.
    Greetings from Yokohama ;)
  8. GettinBetter
    GettinBetter Magna Merchant Gold Contributor
    CAD Engineer
    Kent, UK
    746Coins
    Pn 37 seems high? 5000 is the same as adding 5 coarse steps.
    Away from home at the moment so can't refer to mine.
    @knaufinator has posted his settings which may be a good point to start cross referencing your settings.
    Looks great BTW, good work.
