Showroom My 2DOF driving sim
Discussion in 'DIY Motion Simulator Projects' started by spartan300, Jul 13, 2014.
  1. spartan300
    spartan300 New Member
    Doctor
    Athens
    462Coins
    I have finished and tested my home made 2DOF driving simulator.
    You can see all images that finally got me here at https://imageshack.com/a/WfAz/1
    I use SMC3Utils v0.64 with SimTools GameEngine and works great.
  2. bsft
    looks good there, what control boards are you using?
  3. eaorobbie
    20,494Coins
  4. spartan300
    Doctor
    Athens
    462Coins
    Thk you eaorobbie, bsft.
    Yes iam using arduino UNO R3 with SMC code.
  5. Scratch
    Scratch Active Member
    281Coins
    Looks like a fun ride!
  6. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Well done! Nice build. :thumbs
  7. SeatTime
    Excellent, another running sim. Looks well built:cheers. Were the dampeners front and back necessary?
  8. Pit
    30,505Coins
    Nice rig, IMO the "lateral rocking" is a little too much.
  9. bsft
    True @Pit , and we all set motion to how we like it.
    It does take time to get a motion profile right, after nearly 4 years I still fiddle and make changes.
  10. Pit
    30,505Coins
    @bsft that is why we love our hobby: we are all the greatest scientists and make our progress over the years :)
  11. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    well done @spartan300 nice seeing your sim getting motion
  12. spartan300
    Doctor
    Athens
    462Coins
    There are because i needed my sim to be balanced and i couldn't do it without them.
  13. spartan300
    Doctor
    Athens
    462Coins
    Yes i know. I increased the lateral force for more effect. It isnt correct?
  14. AceOfSpies
    19,614Coins
    Hi @spartan300, nice movement you have there. @Pit is only giving his opinion, its not that the motion isn't correct.
    If it feel right to you, and your happy with it, then it is correct. Try playing with the profile and see if you can improve what you feel. Its all about experimentation, and we all want something different.
    Mike :thumbs
  15. Pit
    30,505Coins
    Viewing and feeling can be different, that is true, so I passed only a remark. What I want to say: it seems that the lateral shaking does not reflect the real feedback of a car within the simulation. The shaking gives you more action, but IMO the turns are softer and smoother as they should be (harder).
  16. spartan300
    Doctor
    Athens
    462Coins
    aaa i see. you're right. I dont know why is that happening. It seems that the RBrally has more brutal movment.
    I will make a video trying LFS in which the movment is more smooth and correct.
    Does anyone play RBR, so that he can see if the plugin has some problems or its just my setting.
    By the way, Thank you all for you good words.:grin:grin:grin
  17. bsft
    rally is usually more "throw " around due to the nature of the driving. While tarmac racing is usually softer cornering.
  18. SeatTime
    Again just my opinion. I'm not a fan of balancing a rig with dampers, as it can cause tracking issues. But if it feels fine to you then that is OK - its your rig.
    • Agree Agree x 3
  19. spartan300
    Doctor
    Athens
    462Coins
    You are correct. That is my opinion too. But you see when i started building my sim i had first made the upper part just to have something to seat and play rally. The idea of putting motion came later, so it was hard to make the correct balance.
    Iam planing a new one starting this time from the motion platform and then ajusting the seat and wheel.;)
  20. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    2DOF, 3DOF, DC motor, SimforceGT, 4DOF
    Ciao @spartan300 se posso dire la mia... hai fatto un bel lavoro :thumbs cè solo una cosa da sistemare secondo me... guardando il tuo video, si vede quel movimento laterale destra sinistra che fa la struttura... non ti da fastidio? si rischia anche di allentare il giunto a snodo con il tempo. Io per ovviare a quel problema, avevo messo 2 braccetti stabilizzatori, in modo da avere tutti i movimenti tranne l'oscillazzione laterale a destra e sinistra.
    vedi foto:
    Hello @spartan300 if you ask me ... you did a good job:thumbs there is only one thing to fix, according to me ... watching your video you can see that movement right left side that makes the structure ... you do not bother you? it also threatens to loosen the swivel joint with time. I do to remedy that problem I put 2 arms stabilizers in order to have all movements except oscillazzione side left and right.
    see picture:
    (e solo un consiglio);)
    (and just a suggestion);)
