Question Motors informations (RPM, ration, Nm) for a beginner
Discussion in 'New users start here - FAQ' started by alenig, Feb 15, 2017.
  1. alenig
    alenig New Member
    Turin (Italy)
    118Coins
    Hello, :sos
    first of all I introduce myself, my name is Alessandro and I'm from Italy. I just decided to start with my first DIY 2 dof simulator project.
    After reading many and many threads regarding the possible system to adopt, I choice to use 2 Pololu Jrk 12v12 with 2 motors behind my seat.
    Now it's time for an hard choice: which motor should I use (good quality/price)?
    I would like to say that I am not an expert in mechanics so it is difficult for me to understand all the aspect to take into account during the motor choice. For this reason I decided to open this thread, so I will ask some questions:
    1) Some of you have already found good motors (in terms of quality and price)? It have to be accessible also from Italy.
    2) Could someone help me to understand the technical aspect of RPM, ratio and Nm?
    3) How can calculate the RPM, the ration and the Nm that I need for my 2 dof simulator?
    I take the opportunity to say sorry for my not perfect english :grin:grin:grin
    145,124Coins
    +10,778 / 52 / -2
  3. alenig
    alenig New Member
    Turin (Italy)
    118Coins
    Thank you very much for your quick reply.
    Due my english, I'm not sure that I well understood the meaning of CTC lever. Is it the metal bracket builded to connect the motor to che arm?
    145,124Coins
    +10,778 / 52 / -2
    Yes you got it, he CTC is the Center To Center distance on the lever from the shaft center to the hole in it where the arm connects.
  5. alenig
    alenig New Member
    Turin (Italy)
    118Coins
    If I consider the characteristics here below, is there someone that have some advise for me (both in high or lower value)?
    12v DC, 180W, 50:1 gearbox ratio, 20N.m, 80 RPM output speed
    Thank you in advance!!
    145,124Coins
    +10,778 / 52 / -2
    Motor choice depends on the design but those would work for a lot of them.
  7. obobo
    obobo Active Member
    1,323Coins
    for 2DOF, it's good
    for 3DOF, with 3 motors it's small
    for 3DOF with 4 motors, its good
  8. Pit
    30,416Coins
    From the technical viewpoint I really doubt you will get a 3 DOF working with 180W motors, especially if we have monitors, OSW or other gadgets attached to the rig.
    145,124Coins
    +10,778 / 52 / -2
    You would need some form of heave assist, but monitors would kill it.
  10. obobo
    obobo Active Member
    1,323Coins
    a 3DOF roll pitch heave seat mover !!
  11. Pit
    30,416Coins
    As @noorbeast mentioned you need a heave assist f.eg. in form of a spring or gas strut
  12. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    Ciao Alessandro, da Roma!
    Hi Alessandro, from Rome! I'm in the same situation, I want to build a 2DOF compact, with motor under the seat. The best thing that you can do to start, is to build a small RC model to understand all of theory behind simulation and you can be confident with simtools (the software for the simulator).
    You can easily build it with Arduino and 2 RC motors.
    Here you can see my little model in action:
    After that you can think about simulator .. if you want to put motors under seat you need 50:1 or 60:1, and if you want to use JRK you must stay under 16/20A load. Other parameters are not very important, except speed (70-80 RPM is good).
    Anyway, why you want to put motors on back? If I can give you advice, I would suggest to put motors on front under the seat, so the sensations of corners are more realistic (build little model and you can see this thing).
