Motorcycle 2dof sim motogp18 issues
Discussion in 'DIY Motion Simulator Projects' started by 204flightsinmotion, Jan 18, 2026.
  1. 204flightsinmotion
    204flightsinmotion Member
    209Coins
    So thanks to all the help on the forum I’ve almost finished my 2 dof with a. Kawasaki ninja project. But I’m having issues with motogp18. It’s pretty much the only decent motorcycle game that has telemetry and for some reason when I hit a wall or wipe out in the game the motors start shaking abruptly and then don’t stop. Only fix is to unplug the usb to the arduino. When I plug back in they go back to there parked spot which is good but I have to exit the entire game to get them working again. Basically making it unplayable.
    Anyone run into these problems? Any advice.
    153,770Coins
    +11,149 / 57 / -2
  3. 204flightsinmotion
    209Coins
    Yes I am using simtools 3. I’ve tried with crash detection on and with it disabled. Same issues with it causing my motors to spas and no way to recover from it. Super annoying. Any tips
    153,770Coins
    +11,149 / 57 / -2
  5. 204flightsinmotion
    209Coins
    Is there anyway to reset the motors other ths disconecting the usb? Trying to find a workaround for this , since I can’t seem to figure out a fix
    153,770Coins
    +11,149 / 57 / -2
    I suspect restarting SimTools or the computer.
  7. Joe Cortexian
    Joe Cortexian Active Member Gold Contributor
    1,537Coins
    I think that SMC3 is locked up t that point. You could wire up a momentary button to the reset pin on the Arduino. I suspect you just ground that. If SimTools isn’t connected to a game it might recover. If it’s connected to a game I suspect it will need to be restarted.
