Motor w/ Levers vs. Linear actuators any special considerations in operation?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MBak, May 10, 2023.
  1. MBak
    MBak New Member
    40Coins
    Hi
    I'm planning a 6DOF build. I'm deciding between motors with levers and linear actuators.
    Are there any special considerations when using a motor with levers? Someone told me I have to consider the "sinusoidal" movement of the motor levers vs the linear movement of the linear actuators.
    If I did a build using linear actuators, and then swapped them out for motors with levers, it seems that I would get different motion ?
    Make sense? Or is it nothing to worry about?
    Thanks.
  2. Gadget999
    11,947Coins
    Simtools will compensate for the difference in motion
  3. m50b20
    m50b20 Member
    100Coins
    Really ? By feedback ?
  4. Gadget999
    11,947Coins
    It works out the difference between linear and rotary motion automatically
  5. Gadget999
    11,947Coins
    Linear actuators look very cool, but are expensive and noisy imo
    They have very good range of distance, very suited to a flight sim
    Gearbox and levers have quite a lot of power for the cost and can accelerate quickly making them suitable for driving sims
    somebody did make a linear actuator that used a belt and motor, could also be done with a simple chain amd sprocket !
