Motor Selection-AC Servo Vs Async AC
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by aliotic, May 30, 2015.
  1. aliotic
    aliotic New Member
    Iran
    293Coins
    2DOF, 3DOF, 4DOF
    I am building a 4dof motion simulator platform. In my previous design I used Delta ASDA-B2 AC servo drive and motors which worked fine. In order to reduce costs I changed the design to use Delta VFD-B with asynchronous AC motors coupled with an encoder using and additional extension card on the VFD( PG01 card), but to my suprise the VFD only generates speed outputs and I was forced to use open-loop designs. In both scenarios the drive is directly connected to the PC through an RS-485 converter.
    I did a quick search in the forums but couldn't quite make out what control structure and connections are used.
    I would appreciate help on the matter.
    154,831Coins
    +11,227 / 57 / -2
    This is the AC guide in the FAQs and @speedy is a good person to give more specific advice about AC projects: http://www.xsimulator.net/community...-every-thing-needed-for-motion-simulation.43/
  3. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    @speedy is the AC guru here. Read his guide in it's entirety.
  4. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,951Coins
    Thanks guys ... but I'm not that much .
    Can you please describe here in details how they worked fine in a 4dof motion simulator platform ?
    please share your experience on such servo system so maybe we can help reducing the cost .
    Thanks ...
  5. Mehmetbaran187
    Mehmetbaran187 New Member
    Turkey
    470Coins
    I am trying to build my own actuator and i was wondering about the same Delta motor (ECMA-C20807RS) and ASD-B2-0721-B drive.
    I have a few questions for you.
    Did you used these motors as actuators?
    How was the performance?
    Does it compatible with Thanos board?
    Thank you
    154,831Coins
    +11,227 / 57 / -2
    This is a really old thread, which has not been updated since 2015, it pre-dates current servo use, @Thanos controller and DIY actuators.
