    Buy Download Package Now!
Motor Problems
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Sam Neall, Dec 19, 2019.
  1. Sam Neall
    Sam Neall New Member
    190Coins
    My motors make a rumbling sound when I turn up the PWM max on SMC 3. They don’t move and the feedback is all over the place. Attached is a pic of what it looks like in smc.
  2. Ads Master
    Ads Master
  3. SeatTime
    Newcastle Australia
    27,326Coins
    Try some screened cable for the feedback line, or add in some deadzone in the SMC3 app.
  4. Sam Neall
    190Coins
    Is the Feedback line the wire running from my Arduino to my motor driver? I am using a sabertooth driver btw. Also I’m not really sure what you mean by dead zone. I’ve set limits if that is what you mean.
  5. SeatTime
    Newcastle Australia
    27,326Coins
    The feedback line is from the pot on the motor back to the Ard. SMC3 deadzone.. try 1 or 2
  6. Sam Neall
    190Coins
    I will try the dead zone. When I was putting on the pots I would sometimes move the arm and the feedback would jump up and kind of go crazy. It could possibly be the pots themselves. I will check it out. Thanks!
  7. Sam Neall
    190Coins
    OK so I installed shielded cables and played around with the dead zone and I’m coming up with the same results. I have my power supply and my motor driver right next to the Arduino. Do you think if I moved the Arduino to a different location it would help? All the cable is shielded except for a few inches of the pin connectors I have to use for the Arduino
