Question Motor for G head torque mode system suggestions? How to convert kg to kg-cm to nm?
Discussion in 'Motor actuators and drivers' started by Trigen, Aug 3, 2020.
  1. Trigen
    Trigen Active Member
    2,891Coins
    Hello chaps!
    Im getting a bit closer to having the parts for my G head system but im still not sure on the motors. It will operate in torque mode so i need to know how many newtons for example 3 kg is on a 10cm motor arm. Im not entirely sure how to calculate it. If i do 3 kg-cm i would need to do 10 x 3 = 30 which is 3 at 10cm? If i convert that to Nm i get 2.94 which i dont think can be correct since my SFX motors are rated at 2.4-7.1Nm
    I'd also love to see some suggestions on motors which would be good for this application. I dont want to use a gearbox if it can be avoided put perhaps planetary with a dual way gas damper on the arm could be ok. It would probably be a lot cheaper but i want minimal backlash but the main reason is that I don't want any resistance when there's no forces acting so i can move freely. That said i doubt i will notice much when racing in my SFX150 and G seat rig as they will do all the instant forces. I can keep a very dampened and just have a force on the head. For flying its a bit more important to have a minimal feel of any gears and such
    There's also stall current to think about? Is it a good idea to go slightly higher on the NM?
    I will be using a Sabertooth 2x32 at 12 or 24v
    153,884Coins
    +11,154 / 57 / -2
  3. RacingMat
    21,082Coins
    it's proportionnal
    3kg at 10cm = 30kg at 1 cm = 0,3 kg at 1m
    and convert 1kg = 1 dN = 10 N
    0,3 kg at 1m = around 3 N at 1m = 3 N.m
