Question Motor for 2dof
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by absyfadhel1, Dec 15, 2020.
  1. absyfadhel1
    absyfadhel1 Member
    bahrain
    192Coins
    Is this motor good for 2dof?
    https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    I used wiper motor but its hard to move so i think this one will be good and stronger is it?
    This is my build (Note: i change the rod position to make it 90° when its senter so dont worry about the rod...
    https://www.xsimulator.net/community/threads/motor-bad-power.15413/
  2. Ads Master
    Ads Master
    117,037Coins
    I use those motors on my compact rig, but with 60:1 wormdrives for greater torque.
    The standard 25:1s can operate for light loads in a compact design, but will be working pretty hard.
  4. absyfadhel1
    absyfadhel1 Member
    bahrain
    192Coins
    Can you give me a link for good and cheap motor?
    117,037Coins
