Question Motor Couplings Vibration
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MrWolf, Oct 30, 2020.
  1. MrWolf
    MrWolf New Member
    23Coins
    Hi all, just working up my 6DOF Linear Actuator prototype and getting reasonable vibration and noise. I notice the shaft coupling rotates out of round when attached to motor and spun without the screw attached. It’s a standard two piece aluminium coupling with the orange flexible rubber insert. Has anyone found this also. It might not be a problem but maybe there are better couples out there that don’t have this issue. Thanks.
  2. SeatTime
    Sounds defective - send it back.
  3. Gadget999
    12,132Coins
    show us a photo of the coupling
    could you use a UV joint instead ?
