    Buy Download Package Now!
Question Motor control accuracy
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Mengxi, Jun 14, 2018 at 12:10.
  1. Mengxi
    Mengxi New Member
    Suresnes
    13Coins
    Hi all,
    I use an encoder to feedback the position in order to get my motor moving as expected.
    It works with bearing not more than 1 degree error and some adjustments before stop.
    However, when I want it to trumbling, like 0 deg, 20 deg, 0 deg, 20 deg....
    It goes very wrong, up to 9 degrees error at some positions (for an example, 0.4 deg, 25deg, 0 deg, 28.2deg...).
    Is there any advice for improving the accuracy of this situation ?
    Or improve the accuracy for the whole system, such as less adjustments ( adjustments create unexpected shaking occasionally ).
  2. Tim McGuire
    Electrical Engineer (Student)
    Canada
    1,766Coins
    3DOF, DC motor
    What are you using to control your motors? Are you running a PID loop?
