Question Motor bad power
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by absyfadhel1, Oct 29, 2020.
  1. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    Hi...i have 12v wiper motor and i try everything to make it work fine but unfortuantly i could'nt do that....i tryed to make the motor in the front but no enught power to move ...i try to make it in the back but it was the same ...i add a spring in the diffrent position (motor in front =spring in back and like that) but nothing change the motor cant take weight i bought about 6 diffrent motor but i lost my money on nothing...help
    Note: i already used (simcalc) software please dont tell to use because i used it before..
    I use 2 computer powersupply connected together does it matter to use pc powersupply or this type of powersupply?
    I use 2x of this
    You think if i use this type i will get more strong motor?
    Hope you help me guys
    This is a photo of my setup...i already change alot but its same i kept the seat only but nothing change i thought if i use the seat only i will loos weight but nothing change
  2. Ads Master
    Ads Master
  3. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    Note: this photo is old...i already change the position of the rod to make it stright like simcalc advice
    118,672Coins
    I do think LED PSU or modified server PSUs are you best option, though that it not really your problem: https://www.xsimulator.net/communit...ver-power-supplies-as-cheap-powerful-psus.54/
    As per previous advice wiper motors are not really adequate for a full frame compact design with small inherent leverage, you need much more powerful motors for that: https://www.xsimulator.net/community/threads/motor-2dof.15366/#post-207051
    Shoulder mounts or foot mount best suit wiper motors, as both have a lot of inherent design leverage, something like this: https://www.xsimulator.net/community/faq/shoulder-mount-rod-angles.149/
    I understand that is not what you would like to hear, but unfortunately with small motors you have to compensate with increased leverage in the design.
  5. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    Ok...you know from where can i get good motor? I mean from recycle? Like old car like scoter motor maybe?
    118,672Coins
    An electric wheelchair is likely your best bet.
  7. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    118,672Coins
    For a compact design ideally you want something around 200-250w, preferably with 60:1, which should give about 35-40nm torque, those linked have too little torque for a compact design.
  9. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    But it must be stronger than the one i already installed
  10. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    118,672Coins
  12. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    I will check tomowro the car scrap and check the motors value....i must get more than 75rpm right?
  13. noorbeast
    118,672Coins
    It is not so much the rpm but the torque the motor puts out that is important.
    From @Kieth's build the motors he used can at least drive a knee mount design, though it is not clear what the torque output actually is.
  14. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    but if i put a spring in the back of the seat to help polling up will be better .. i want to know is this motor better then 12v wiper moter ?
    the motor i use its moving but hard to move and i think this motor will make diffrent
  15. noorbeast
    118,672Coins
    The best advice I can give is that if you want to use weak motors then go for a design that has a lot of inherent leverage, like a shoulder mount, or if you want a compact design look for a motor of 50+rpm and more importantly 35+nm torque.
  16. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    I have one good news and one maybe bad...
    The good news that my motor now work great and can carry the weight.
    The bad one is the motor goes very hot.
    How can i reduce hot temp? Is it normal?
  17. noorbeast
    118,672Coins
    The motor is hot because it is being overloaded.
    Reduce the load on the motor or find some way to cool it.
    To reduce the load you can shorted the lever Center To Center (CTC) distance, or move the motor further from pivot point to provide more inherent design leverage, or you may need to do both to reduce the load to a sensible level.
  18. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    ok i will try to do somthing for (ctc)... i found i method to make the motor cool down but i afride its may burn because of heat and air flow maybe burn i dont know if i right but can you look at this thread and tell me if its safe and helped?
    https://www.xsimulator.net/community/threads/dc-motor-cooling.9686/
  19. noorbeast
    118,672Coins
    If I recall there was a member who even resorted to water cooling some wiper motors.
    But instead of buying stuff to work around a problem sometimes it is better to invest in an actual solution, which in this case would be more powerful motors.
  20. absyfadhel1
    absyfadhel1 Member
    bahrain
    253Coins
    In my country there is no dc motor saller.. and my motor now is great and can move easly but i care now for the temperature and i want to solve it... in conclusion can i make hole and put a fan on it ? i dont know what he put in the motor but i know only that he made holes and but air blower on it
  21. noorbeast
    118,672Coins
